4G93T ECU help
Sep 29, 2005
does anyone no where i can get a ECU for this motor or if i cn use the ECU from a 4g63t with it i know the wiring is different and thats my other problem i need the wiring diagram and pin outs for both of these also if anyone has a 4G93T ecu i will buy it if the price is reasonable
speedz1665
612
u can use evo 1-3 ecu's...direct plug and play....
keigo4552
292
kuala lumpur
advise here~~!
hi,ah beh here....
wat the diff between 93t and 63t ecu....if plug and play
first,if u use 63t ecu in ur engine,u need to add FITC in ur engine cause it will adjust the air cond ideling....63t FITC i/c diff with 93t
then,u hav to change the air flow sensor if u using 63t ecu
wat i wanna tell u here is ,if u using 63t ecu,it will more cost than u buy a 93t ecu...93t ecu is cheaper than 63t
wat good and benifit of 63t ecu is it can be chip
i hav 93t ecu.....7377 right?
u think clearly la....
call me if u wan it...
ah beh 016-6000682
office 03-41430920
see u
alo guys,
need help bro.warnna take off my bug-eye kancil bumper.tried once but still cannot.
let me get this straight.firstly,there's 4 nuts to be taken off from the upper part of the bumper(along the radiator side),then,there's one behind the plate number.then,two more at the wheel arc,right?then,is there any more nuts i'd missed?help guys...thanx
