wastegate??, aiyoh that's also have to save some money..when buy wgte, have to buy also the banana..if not tebuk manifold..but p4mance not last..i prefer turbosmart brand..
for me i btter do change the injector, TD05, banana, S.T pipe eksoz & intercoler, walbro pump, and at least emanage blue for fuel management..hehe..don't know when i have money do that..
most i regret last time projct..S.T pipe i.c & eksoz (3 inch), cap thai wasgate & cap ayam fuel regulator..perfomance???..even kenari can tapau me..always cut at 6k rpm..now standard mode..only big ic from e3..feel better..hehe..:proud:
the disadvantage of tebuk manifold is that the durability won't be as long as if u get a SS manifold with a directly hole to plug the wastegate on it...the durability as not a mean for wastegate, as a mean of that maybe after sometimes, they will be leaking around the welding area btw standard manifold and wastegate...
your last time project gadgets doesn't not really influece on your rpm cut....i afraid is your ECU tat play a big role on that..6k rpm cut for mitsubishi's engine? izzit auto?
unless if it is bcause of insufficient or inproper fuel produced after 6k rpm that lead to the end of fuel produced which resulted in 6k rpm cut..
-evo 510cc injector wil cost u around RM350
-TD05 depends from which engine, vr4 or 4g63 evo 1,2,3...price range around 600-1200, half cut condition
-new ss manifold range around 600-1500
-half cut evo3 intercooler 400-700
-new wallbro around 380-450
-new emanage+ignition harness around 1000-1300
-whole SS exhaust piping from downpipe till the end of muffler, around 300-600...
all bros,
b4 this my mechanic use 2 tulang ikan (4 valve each x 2= 8 valve) to boost 1 bar. But he only open 3 valve. so can i just use 1 tulang ikan and open 3 valve instead 2 valve on 1 tulang ikan and 1 valve on the other?
well bro, if u're using tulang ikan to set your boost, u must do a lots of trial...not to say tulang ikan, an analog or digital boost controller also required the same thing..
the pressure of each boost controller + engine settings is different..is not like both using 4g93t, both installed with same item, using tulang ikan as well...the first one open 3 valve to archieve 1 bar, and the other one might open 4 valve to archieve 1 bar...it might because of your vaccuum hose length, turbo's condition, engine's condition and so on..
u can use only 1 ikan tulang if u dislike of using 2...but make sure u play wit it properly..is not an easy set-up because ikan tulang tend to spike or creep, it hardly to maintain at a constant boost unlike a good analog/digital boost controller with solenoid example HKS EVC, Profec, DSBC and so on..
Thanks for the info Yashio and Wira.. wahaha... we always happy boosting 1 larh.. hahaha!
my car coming out soon ... Wahahaa... but not yet TD05...
Actually , what wastegate help ah?? just wanted to know.. if combination of TD05, evo3 injector and wastegate. How was it. ? and if without Wastegate...
the combination u mentioned i think is the most common set-up for a 4g93t users in order to cut cost while gaining maximum performance..
without wastegate also no problem geh, u stil got actuator (internal wastegate) to help u release the air, just that if u're boosting really high, then the internal wastegate might not be able to support the releasing pressure thus creating an unconstant boost that will damage your turbo slowly...if u would like to know more in-depth about internal/external wastegate, u can search around lo..
basically an external wastegate itself do not actually produce any significant HorsePower...is just to hold the accurate pressure to release into atmosphere while maintaining a constant boost that able to regulate your turbo and engine in the same time...when constant boost being archieved, there will be an increment of power...so it is like a subsitute/additional item's that must have combination to gain horsepower..
[H] [K] [S];3788337 said:
if u lav the hi cam sound but cant afford to buy cams, juz change to adjustable pulley. adjust the pulley to maximum retard & ull get that sound... juz lag on power then......
lolzzz...of course lag of power lo, u retarded the exhaust to maximum point...
why don u try exhaust 4' retard, intake 4' advance, or the way round, i forget my settings d...
it will increase your low-end, however decrease in high-end....both must have it's own pros and cons...cam pulley is main for adjusting the value of a higher degree of cam to make it suitable for the settings u implemented into your engine...
if adjustable cam pulley + standard stock cam, u will only notice a slight changes and if setting accurately, u will gain let's say 2-10HP only...while if adjustable cam pulley + high cam, u will gain around 20-50 HP, vary from your cam specification, tunning, and related condition.
