SARD Fuel Regulator which I am selling is original.does the fuel regulator c/w the pressure gauge and mounting bkt for gsr? (izzit from japan, ori?)
btw, the mechanic did test the engine with a stock fuel regulator. manage to get it to 3 bar, but when revving, the pressure drop.. so, pressure drop is confirm fuel pump insufficient right?
I give Arospeed Pressure Gauge, Fuel Rail Adaptor and Fuel hose in the RM450 package.
Bracket you can make ur own.... not difficult la if bring to your mech to install... everything is there oledi....
As I mentioned b4... if stock fuel pressure regulator not faulty and ur press drop when on load... ur fuel pump not up to expectation la. have to change edi....
have the whole fuel system checked for leaks as well la... i never see how ur mech test ma... so i can only guess the usual culprit.
