7.8k manual halfcut??? is very cheap already...i heard my fren say JB area is around rm10k for GSR halfcut...
try adjusting the idle screw located at your throttle body for higher timing.
walbro fuel pump before shipping is MYR380.00 shipping fee MYR8 within Peninsular Malaysia.
Brand new in box with socket and microfilter.
at the moment you may not require any adjustable fuel pressure regulator yet.. unless you plan to fix that walbro in.
there is a reason if the fuel pressure is low when on wide open throttle.
have u tried swapping with a stock regulator which is known to work? if problem persists, it could be the fuel pump. eventhough fuel regulators can fail but i bet RM0.50 the fuel pump is the culprit.
SARD Fuel Regulator (Complete set for GSR) MYR450.00
Walbro 255lph GSS342 Fuel Pump MYR380.00
Postage MYR10.00
Gimme a ring if interested. I have the items in stock. 0164786000 (Raymond) cheers!
does the fuel regulator c/w the pressure gauge and mounting bkt for gsr? (izzit from japan, ori?)
btw, the mechanic did test the engine with a stock fuel regulator. manage to get it to 3 bar, but when revving, the pressure drop.. so, pressure drop is confirm fuel pump insufficient right?
finally, had a new pump install (gsr type).. given along the halfcut. installed. see some improvement during idling.. but still, engine trembling... gah.. shyt arse.. then mechanic check for each cylinder compression pressure from cylinder 1 to 4. he claims that cyl 2 to 4, no prob, because it reach 150 (forgot bout the unit) in few clicks (engine start up sound), but the 1st cylinder needed more clicks to reach 150. So he assume combustion pressure lost in cyl 1. head ache.. which results in incomplete combustion in cyl 1?! recommend service. check piston ring, valve , in other words, overhauling??? die..
mounting condition checked, ok. but i will dbl confirm with another mechanic. the idling rpm now is at 850rpm ah..
just further information, the mechanic check the engine condition by pulling out the spark plug cable, going from 1 to 4. cyl 2 to 4, if plug out, the engine slows down significantly. only cyl 1 doesnt seems to have much effect.
then, the injection plug is pull off 1 by 1, all give effects of slowing down (meaning fuel supply [bigger lph fuel pump] did reach cyl 1, previously cyl 1 pull off injector connector, no sign of slowing down)
gud evening everyone.. want ur guidance n advice la...
im runnin stended gsr now but changed my turbo to bigger than TD04but slightly smaller tahn TD05.. its garreett ar42, dunno from where one la.. n i've install sard FPR.. so now i want to fix e manage+avcr, do i need to change my throttle body, air flow n injector to EVO one's b4 installin e menes? some say its easiere to cut fuel rather tahn increasin the fuel? n metal gasket also fix or no? thanx
Similar threads | |
