4g93 with 4throttle
azahari.aziz
182
anyone try use this throttle for thier engine conversion...
can tell me??
used btop or svtop throttle??
what need to change ecu?? injector??
used with emange or only safc??
how about wiring??
SkYwAlKeR
10,139
300
ePoh ~ malacca
last time my friend's mechanic had a 4g93 mivec 4 throttle
not sure he use the 4 throttle unit from which version
yes ecu confirm need to upgrade... injector recommended... important is do a good intake manifold for it...
so far of all 4 throttle engines i've seen at my mechanic, they use haltech ecu... not sure if emanage ultimate can support or not... emanage blue or safc most probably wont... so, it is best to have a standalone ecu if u planning to 4 throttle...
DonJuanDeMarco
134
they using 4trottle from tyt 101 or 111..
saidi at shah alam sek27 can do it...cun giler..
must use stand alone ecu...
ART///SPEED
287
use standalone as microtech and much more....low cost mivec wiring
Mar 21, 2008
674
15
If your engine is MAF, you need Emanage Blue (Or Emanage Ultimate coz you can throw your Rev Cut n Speed Cut) :thefinger:.
Dont buy SAFC coz it's pretty useless (only good for looks), and you dont need a standalone (coz it cost you minimum RM3500)
cooljas
523
4throttle to work best with standalone ecu...emanage blue or ultimate will not be sufficient enough!
joe_mirage
1,030
44
rotationperminute.blogspot.com
yups correct .. need a standalone ... emanage confirm not sufficient.
The Marketplace Top Posts
helo to all..
anyone know where i can cut my spring? prefer pj and shah alam area la.
not interested to buy sport spring, bcos already install heavy duty spring. higher than stock spring. make my car look like jeep now.. just want to lower it a bit.
thanks
