4g93 block!!!!
8216ks
187
hai guys! i need help bout my block!! i was using a stage 3 mod block last time and it blew to pieces conrod snap due to over reving!!!!
now i am using standard block to run around!!! i wan to mod another block!!! wat piston can i used, i am not really good in modding!! last mod was done by my forman!! now looking around due to very limited fund!!!!
2) my ride was pushing about 160bhp last two month when i dyno!!! if can i wan to reach the same bhp but not spent the same amount!!!!!!
anywan can help!!!!!!!! thanks
4g93 na block!!!!(putra):listen::driver:
deacon
Senior master debater
1,167
30
You just rebuilt your bottom end to get 160? What have you done to the head? Is the 160 at the wheels or crank numbers?
8216ks
187
no bro before my block blow!!!! now standard block only!!! top fitted cams, jun valve springs!!! a few others things:}....160 at wheels bro!!!
joe_mirage
1,030
44
1,648
rotationperminute.blogspot.com
aiyo bro.. that's sad!. make me scare to over rev my 93 block too!!!
btw .. u can opt for 82 mm piston + lighten crankshaft + fully balance the block. hopefully u will get more power than ur previous setup. just my 2cents.
stand to be corrected.
deacon
1,167
30
Block is safety would be to use 81mm pistons 4g92p or 4g92 mivec
joe_mirage
1,030
44
1,648
yups. to be safe n reliable can go for 92 sohc piston or 92 mivec. but have to choose correct metal gasket to prevent knocking. mivec piston dome is quite high. high compression!
just my 2cents.
8216ks
187
thanks bro... looking around now!!!!:adore: u kbow anywan who have it!!!pls do let me know ok...:adore::adore:
mag9556
2,770
43
1,648
I have a fren whom have 4G93 mivec with Mivec piston inside, LSD GB and remap ECU already, all complete like halfcut with custom paper as well and would like to sell it at RM 9,000..
No picture as the engine well keep in garage and close with carpet.. sooo.. sorry no picture currently...
Anyone interested:hmmmm: location at Klang
8216ks
187
good prize and nice engine!!!! but not for me!!!! just did up my top!!!! anyway will ask around if anyway lookin for it!!!!! wat g/b bro and ecu???
joe wat setup up you usin??? mind to share!!!!! this time just wan something that dont BURN a hole in my pocket!!!!.....:adore::adore::adore:......
joe_mirage
1,030
44
1,648
mine just simple setup. matspeed fast road spec camshaft + port polish head + remapped ecu + simple add ons ( mivec TB + gsr intake + lighten crankpulley + blablabla ). but block still standard. hehehe. later will play with block. might as well put in 'oversized' mivec piston. hahaha 82mm! approx to 1.9L 4g93 :burnout:
ttt2345
6
WOW fast car!!! i am also using mat speed cams!!!
ganfh
462
If turboed in the future should do oil squirter on the block or better off without them? Or cheaper to get GSR block kosong? :banghead:
Want to find the clear type one....
i know whoever do the CF bonnet will cover the top with this item..
but i dono where to find this item la???
