4g92(dohc) drag spec for sale
ProTiara
136
Shah Alam
4g92(dohc) High Performance Engine
Spec :
Oversize piston
Piston ring
Main bearing
Thrust washer
Engine balancing
Metal gasket
Port & polish
Triniti clutch disc
Exedy clutch cover
SKF clutch bearing
Pro Grip timming belt
Adjustable cam pulley
Full race spec cam shaft
Oversize throtle body and air intake
ECU (tunning)
Engine harness/throtle position sensor/air flow sensor
portable ECU support system
*Take a note!!!
-ONLY use for 3 times :adore:
-EASY to endorse with JPJ :biggrin:
-NO need more modification :nurse:
-READY to battle :driver:
Call me @ 012-6475445 (Shafiq)
iz282
4,966
18
PM me best price bro.. + contact no. Thanks
PAHAM
195
bro intrested here
qoute me for
1.adjustable cam pully
2.trinity clucth disc with exedy cluth cover
3.skf clutch bearing
4.pro grip timing belt
012-7631694 zul
Hi all,
I'm planning to diy a MegaSquirts V2.2 to my saga lmst year 2004 to convert from carburetor to EFI system.The question is the throttle body,injectors,all the sensors,fuel pump,distributor,intake manifold need to use from a set of parts from 4g15/13 efi system?All the sensors from 4g15 efi system can b work with megasquirts or not? Also how much do the hardware that i listed cost? pls give some advice n comments thank you..:biggrin:
