12 LED replacement bulbs for MYVI Reverse Light (T10 wide/W16W)
Nitro-Meth
40
T10 wide wedge(W16W) High Intensity LED bulbs(same size for MYVI reverse light). Cool white in color(6000K). Low heat and low power comsumption with 12, 3mm flat head LEDs.
THIS LED REPLACEMENT BULB IS NOT SUITABLE FOR ALL CARS!!!!!!!! Please check before purchasing.
Only selling at RM50 per pair nett.
Currently available :- T10 wide(W16W) White LED - 4 sets/pairs
Coming soon :- LED SIGNAL LAMP REPLACEMENT KITS FOR MYVI(Kit includes :- 2 pairs(4 units) of T20 wedge 24LED AMBER BULBs, 1 unit Electronic Signal Relay)
ALSO AVAILABLE, T10(LAMPU KECIL) 1W LED REPLACEMENT BULBS FOR MOST CARS!!!!!! DON'T MISS THIS CHANCE, GOES GREAT WITH HID OR WHITE HEADLIGHTS. CHECK IT OUT WITH PICS....
http://www.zerotohundred.com/newforums/showthread.php?t=115131&highlight=LED+replacement
Please PM if interested....
1 PAIR SOLD, 1 BOOKING, 2 PAIRS LEFT!!!!! 18 OCT 06 GRAB IT NOW!!!!!
Nitro-Meth
d3ns
55
where do i get this ? where can i take a look? interested buyer here.
Nitro-Meth
40
andrew85 said:
if i buy the bulb got coneter ar
Andrew,
I think you mean connector? Well the bulb uses the original connector, therefore you don't need one. It fits into your existing socket.
Nitro-Meth
Nitro-Meth
40
Bro,
Which light bulb are you refering to? The T10 1W in my other post fits into most(95%) of small bulbs inside the headlamp. No modification needed.
As for the T10 wide I only know that it fits the MYVI reverse and WISH reverse lamps only the others you have to check on your own. That is why I have attached photos with my post as a comparison for you to check first.
Nitro-Meth
XtasyM said:
does the size is same as wira small bulb size ??
Harith
553
B.B.B
is the item still avilable...
pm me best price? loc?
very interested...
cheers...
Wiper blades are like squeegees. The arms of the wiper drag a thin rubber strip across the windshield to clear away the water.
When the blade is new, the rubber is clean and has no nicks or cracks. It wipes the water away without leaving streaks. When the wiper blades age, nicks or cracks form, road grime builds up on the edge and it doesn't make as tight a seal against the window, so it leaves streaks. Sometimes you can get a little extra life out of your wiper blade by wiping the edge...
