Hi Fellow Car Owners,
LED replacement bulbs now available via Mail ORDER :)
T5 LED bulbs
T5 Wedge Bulbs each with 2 High Flux LEDs which is FAR Superior than single LED inverted bulbs which are pretty dim in comparison!!!
120 Degrees angle of view. Suitable instrument clusters which require use of T5 bulbs.
Price:
BLUE, WHITE - RM15 / Pair
Cabin Lights
Latest!!! Cabin Lights Now Available Suitable for car interiors.
There are 2 types.
1 Watt Festoon Bulb
1. 1 Watt Festoon 31mm Bulb (build in 6 Chip LED) available in Blue and White
Price - $28RM each
3 Watt Light Panel (15 Super Flux LEDs)
2. 3 Watt Light Panel (15 Super Flux LEDs) available only in White (Festoon 31mm and T10 adaptor available)
Price - $58RM each
T10 Wedge 4 High Flux LEDs
Colors includes WHITE Blue Red Amber
T10 Wedge can be used in the following locations most cars.
1. Front Position Lamp
2. Side Turn Indicator
3. License Plate Lamps
4. Speedo Meter Lamps
Price - $23RM / Pair Excludes shipping.
1. Bulb with 4 Super high flux LEDs which are brighter than conventional LEDs.
2. 120 Degree Viewing Angle
3. Brightest pair of T10 LED bulbs you can get for $23RM
T15 Wedge 9 Super Flux LEDs
Price - $46RM / Pair Excludes Shipping
1. Bulb with 9 Super high flux LEDs which are brighter than conventional LEDs.
2. 360 Degree Viewing Angle
3. Most suitable for applications where side firing LEDs are required.
4. Best pair of T15 LED bulbs with 360 degrees angle you can get for $46RM / pair
5. Physical Dimension 35mm(Length) X 15mm(Width) X 9mm(Wedge Base)
Important: These T15 9 Super Flux LED bulb's dimension are larger than conventional T10 Wedge Filament bulbs, so Please confirm that your application can accomodate this bulb before ordering.
Important: These T15 9 Super Flux LED bulb's dimension are larger than conventional T10 Wedge Filament bulbs, but the base for T15 and T10 are the same (9mm), so Please confirm that your application can accomodate this bulb before ordering.
Don't know which bulb to get?
Please note that T15 9 Super Flux LED's dimension of 35mm Length and cross section of 15mm X 15mm (Square shape) . This is bigger than conventional T10 Wedge bulbs.
So you MUST confirm that it fits your applications. Else the T10 4 Super Flux LED is a good alternative.
The T15 9 super Flux LED is designed for applications which require 360degrees of viewing angle. As the light is spread out into a very wide angle, it might not look as bright as the 4 Super Flux LED from the front.
In general, if the pole light is more or as pointing forward, the T10 4 Super Flux LED is recommended. If side firing LED is require then T15 9 Super Flux LED is recommended.
Payment will be via Interbank Transfers to.
RHB Bank Account (Malaysian Savings Acccount). Full Account information will be provided upon confirmation of product order.
Shipping to Malaysia will be via Registered Mail with Tracking Number and Shipping Insurance from Singapore. So you do not worry about loss of items.
Shipping Cost in Malaysian Ringgit
1st 2 Items $7.00 RM
3rd Item onwards $1.00 RM per item.
MASS ORDERS welcome, Free shipping for orders over 10 Pairs!!!
Any ORDERS or Questions please email [email protected]
Once Bank Transfer to RHB Bank Account (Malaysian Account) is verified, Registered Shipment will be dispatched with Tracking Number provided to you.
For updates and Pictures to the NEW In Car Cabin lights, please goto
Super LED Shop - Online - High Powered Automotive LED Bulbs for Sale for more details!!!
Thank you for your support!!!
T5 LED bulbs
Price:
Cabin Lights
There are 2 types.
1 Watt Festoon Bulb
Price - $28RM each
Price - $58RM each
