just bought dc5R
bzen
85
nilai
Re: just brought dc5R
Woww......hondata+Intake + Exhaust + Header+tune wht the buget??anyone experience???
hondata+Intake + Exhaust + Header is it enough for dc5?
jaymie
149
9
Hondata k100 - rm 2500
Toda header - rm 4800
Exhaust custom made - rm 1500
Intake custom - rm 500 (rough estimation)
Total - rm 9300
P/s you can cut cost at the Header section if you buy other brand , example such as Kidd racing (rm 2200)
NukeeZoid
2,330
176
further_seems_forever.blogspot.com
you have to pay to play bro. :biggrin:
i spent close to RM10k within the 1st 3 months of owning my car. its a poison you cant get out of your system once you start.
i/h/e/hondata are just BASIC mods for the DC5.
the next stages people usually look at are:
1. Intake Manifold (RRC or Skunk2)
2. 70mm Throttle Body
3. Cams paired with upgraded valve springs
It really depends on what you want to achieve at the end of the day. Whether its a HP figure you're chasing, or a time attack goal... its all subjective. The great thing about the DC5 is that is responds very well to mods. Even light mods like an air intake kit will garner significant results.
But the most important thing to remember is to HAVE FUN along the way and dont get too caught up with chasing a figure that you forget to enjoy yourself.
:driver:
hondafreak
751
kelana jaya
How much cost for d RRC or Skunk2 intake manifold? Do we need to change d wider throttle body simultanously? *Note-due to budget constrain... :(
prasath_5338
1,131
19
Or you can PM me for bundle pricing....im demoding....
bzen
85
nilai
wht the feel after install hondata+Intake + Exhaust + Header+tune ?how many horsepower increase?
---------- Post added at 12:13 AM ---------- 6 hour anti-bump limit - Previous post was at 12:01 AM ----------
which one mostly the primary choice?
Turbulence
201
7
haha..prasath...u r doin end year promotion here?????
---------- Post added at 07:36 AM ---------- 6 hour anti-bump limit - Previous post was at 07:32 AM ----------
erm...i found it much more responsive and powerful.....hp increase about 30 or more on wheel dyno....torque can increase up to 21Nm
jd5
158
9
N/A
Hey guys,
Sorry to be off topic, but I have a bit of a question on 02 sensors.
My CEL came out recently, so i checked the oil and everything and all seemed ok. I resetted the ECU, and then the CEL went off. Just to be sure what it was, I went to the mech and was told that the 02 sensors are gone, and needs replacement.
I know there are 2 sensors, but how would I know which one needs to be replaced? Is there a way to check them? I know you can use a voltmeter on a TPS sensor, but what about O2 sensors?
bzen
85
nilai
ha.ha... check at jcracing .i hv it prob b4..but mostly the primary o2 senser gone after then secondary..u got feel ur car like "petrol gone fastly"
---------- Post added at 09:18 PM ---------- 6 hour anti-bump limit - Previous post was at 09:14 PM ----------
woW...increase 30hp after install i/h/e..
if install i/h/e+Intake Manifold (RRC or Skunk2)+70mm Throttle Body+hondata+tune
wht the buget n horsepower increase?
jd5
158
9
N/A
Bro, thanks for your reply but I was asking how do you know if the primary or the secondary sensor is gone? I'm guessing most guys would play a guessin game by replacing one of the sensors, and see if the CEL disappears or not (or check the error code again).
I dunno la, I'm just guessin. I want to avoid replacing both cuz they are not cheap. I have already washed them, so see if the CEL appears again. Hehe..
bzen
85
nilai
u can install hondata bypass the O2 sensor.u change the o2 sensor is about rm900 to 1K..is better u add more $$$$$$$$$% to replace with hondata..if u want mods ur car..
Vagabond
1,731
53
1,648
only bypass the o2 sensor if your hondata is running open-loop all the time.
if you intend to run on closed-loop, o2 sensor is still necessary.
bzen
85
nilai
hi all bro got mugen GT wing for DC5.i looking it....
sms me if u want sold
0126296977
The Marketplace Top Posts
Helo everyone!!! Just a newbie on car...I got this Mitsubishi Lancer 4g15 12v SOHC with c62 body (A month ago). Engine is still in great condition but it lacks power. I went to the mechanic and had the clutch assy replaced with aisi disk and excel pressure and release bearing. Even the timing belt was replaced and valve tuned. However on long drive, my car jitters on 1500 rev especially during gear shift. Could it be a defective clutch disk?
Another thing, may i ask what could be done in...
