Performance Plug Cable for B series
cad843
403
12
3,018
Oita Ken
I have dig all the old thread and still confuse which one good enuf .. some say nology good .. some say not good .. some say spoon and so on ....
Whats the difference between red and blue color ? I'm not looking for high performance meant for track but just enuff giving a better response for daily driving, reliability, and doesnt harm my engine and its parts ... Coz some say nology will make our spark plug easy to kong la ..
Pls comment ... TQ
rakyat
106
36
Pls comment ... TQ
Refer to the tread - 'modification that don't work' - conclusion is go buy new oem and don't pay additional $$$ for aftermarket as the difference is negligable. 1 person dyno-tested and nology sapped 7 hp i.e. - 7 hp using nology.
I always suspected as I could not feel any difference despite change plug cables for several of my cars (all hondas) including spitfire & ngk.
akuma
3,489
152
Kuantan
IMHO,if ur engine is relatively stock...stick 2 OEM..n yes,purchasing brand new OEM will gif u improved performance as u cud b loosing sum power due 2 d wear & tear of d seasoned plug cables.
but as for Nology sapping hp,i beg 2 differ.n too many pages on dat 'modification that don't work' thread,cudn't catch up lar.....
anyway,i sure hope d dyno was carried whr d Nology is brand new or is in good working condition...coz used Nology r quite fame 2 haf intermittent problem..i went thru 2 sets b4 settling on my current Nology whc do really help in high rpm range....n do keep in mind,nology oso got fake 1 ler..hehehehhe
cad843
403
12
3,018
Oita Ken
Any comments on Sun Nology and Inadzma Nology ... whats the differ? I know its not helping on HP but settle my jerking prob when changing the gear. Let say I aim for stage 1 mods ... is it performance plug cable helping on response or its just a myth
I aim for new one not used ... Let say between Spoon n Nology which one u prefer?
xtremeleo
3,247
464
5,183
the set was new sir, dont worry..
rakyat
106
36
Speaking of the devil :proud: Mayb u can share ur nology xperience with TS.
The time when i was shopping for plug cables most shops recommend nology - of course-la it is THE MOST XPENSIVE cables + fancy grounding cables attached. But the thought of spending so much $$$ on a questionable mod :stupid:
But when I look at poremen cars, mostly using oem or NGK blue so went with ngk - IMO still waste of $$$
xtremeleo
3,247
464
5,183
it wasnt on my car sir, i wont waste money on sumthing as expensive in the first place also. it was on a customer's car, we did a run before the nology was installed in, got a reading. then installed the nology, got a reading, depreciated 7hp. aik??!!! owner lagi bengang, 780hengget tu!!! then change back to the original used set, got back dat 7hp, aik??!!!
hahaha, then i started my so-called research on which is the best cable, bang for ur buck. nuthing beats the oem, cheaper and performs better then a set of 700++ cable :chuckle:
---------- Post added at 05:39 PM ---------- 6 hour anti-bump limit - Previous post was at 05:36 PM ----------
plus, iam not the devil sir, at least not yet.. :grow fangs:
EGNINE
513
65
3,028
got also so called performance plug cable which is cheaper than OEM hehehe
xtremeleo
3,247
464
5,183
no doubt sir, i especially like the bosch cables, but very hard to source out for my 4efte, so i went to custom a set for my engine. i used a set of trd 4efte plugs, and this custom unit is way2 better then a used trd. yeah, yeah.. i heard u, comparing a used unit with a brand-new-outta-the-box, mana adil kan? but when comparing a set of used trd costs around 300 nowadays, which one wud u use sir? id choose the custom made brandless (well, maybe i can rebrand it to XL(XtremeLeo) engineering? lol) everytime
cad843
403
12
3,018
Oita Ken
Do u mean the performance plug cable not perform as their advertisement? U say that u custom ur cable ... what is the factor consider to ensure the engine having or sufficient with spark produced ... cable size? material? I just wonder if the plug supply too much, too less or just a correct supply to the engine. Thx for sharing
xtremeleo
3,247
464
5,183
sorry for the late reply sir
most of them dont, like i always said, marketeer.. i customized my cable because its next to impossible to find a new set of spark plug cable for my engine, so i find a company dat may be able to perform it. it wasnt cheap if i may add, but was well worth it
sizes, material, all contribute to the performance sir, but the main thing is the interference is kept at bay, to keep the voltage level stable, so the outer jacket is the most important part, i think magnecor uses this approach in the cable design. i dont think too much a spark will do any damage to ur engine, not if the tuning is done correctly.
xtremeleo
3,247
464
5,183
sizes= bigger better..???
not necessarily true sir, although from resistance pov, bigger diameter does decrease the resistance.
most of the cable resistance ive meassured is around 9~20 ohm jer (some of the cap ayam has less resistance then the so-called performance cable :shrug: i dunno?), so dat doesnt contribute much to decrease the level of voltage (in the range of tenth of thousand, usually around 30k volts) transmitted through the cable, but id rather pay much attention to the interference contribute by the cable to its surroundings and most importantly, from the surroundings to the cables.
the main thing is, the outer layer dat is used to avoid radio/ magnetic interference. the inner core uses carbon to cut cost imo, id rather have metal core if i have dat option
First, let me intro myself. I am just another sales man cum installer of car alarm system which had a few years of experience in this field. In the past few years, i found out that many people doesn't really know what a alarm can help them to protect their beloved rides, their belongings, them self and most importantly, their family members like spouse and children. This thread serve a purpose to be a basic education material that most car owner should know about it, the important and...
