4AFE Turbo vs 4AGE Blacktop
n0th1n
1,161
12
japan
junk-dealer.blogspot.com
Wait until u see my car off boost,its the slowest car in the world,even myvi can potong,and full boost also not that fast...:bawling:
But in this case,i vote for 4AFE Turbo...
takpe, asal dari 'jauh bunyi bunyik berdentum-dentum'
translate: nevermind, as long the sound 'dentum-dentum' can be heard from far awayyyyyyyy
nappx
2,532
185
5,163
kLaNG-kEy_tEE
cusco...diff level..diff brand..but...monster la..like u said..baru beli best..suda lama bawak suda tarak best..mau upgrade lagi..he he
cuscostrutbrace
987
62
3,028
haha...siap ada translate
itu bunyi kalu awak mau pun bole,kasi tukar muffler sajer...tp bunyi dentum2 tak laju nak wat ape,sedih betul..minyak pun kuat,aduhai sendiri cari penyakit..
---------- Post added at 04:32 PM ---------- 6 hour anti-bump limit - Previous post was at 04:22 PM ----------
biasa la,ape ape keta pun macam tu kalau dah kaki ada batu,hehe...unless 500hp ke atas,baru rasa puas kot
my car tak monster mana pun,body berat bro,silap2 kena tapau ngn 4afte or 4efte ke nnt buat malu jer,tp kalau 20v n/a tu bleh la layan lagi,tp its not fair la compare n/a dgn turbo ye tak...huhu
Veloc
3,234
991
Sabah
Wow... Suddenly so many reply...
Well, about 16v, I am not a fan of that engine. although max-out tune is much more powerful than the 20V, but I am looking for good economy & drivability also. 16V lacks the VVT mechanism thus it is running on high cams and high duration cams full time. This causes FC and low end torque to be poor. I prefer 20V. although max-out tune is not at powerful as 16V, but it is good for day to day driving.
Concerning supercharge, haha... No offense. But I don't like the idea of wasting the energy at the exhaust gas and drawing energy from the engine itself to supercharge back the engine... And supercharger is not so rev friendly ^^.
What I am looking for is... In about 4 years time (mid-term aim). Good Fc. Good reliability. Not so high maintenance. Decent torque and power (no need insane power).
In long term, (around 6 years time), I am aiming for GOOD POWER.
So now, I have to chose an engine as a base. It is either:
i. Stick with 4AFE. Boost it lightly. After 5 years, up the boost for max power.
or
ii. Get a 20V halfcut. Use it stock. After 5 years, boost it lightly with minimal mods. (because I don't want to touch the internals. High boosting 20v is a lot of work.)
---------- Post added at 06:35 PM ---------- 6 hour anti-bump limit - Previous post was at 06:34 PM ----------
Actually my debate within myself is only between these 2 choice....
danny_rigid
1,598
2
Cheras
www.epmotorclub.com
thread discussing BOT weh!!!! balance of high comp system with turbo and characteristic is also different.
Just read this thread..............hmmm.......if Samuel was here.......it would save all those rumbling and mumbling.........................:itsme:
n0th1n
1,161
12
japan
samuel was 4afte right? unfinished business and now happily with 20v 4age. no more turbo. but i also got a friend who owns a 20v 4agte, not finished also.
p/s: my friend's BOT kit for blacktop is with me now, summore for sale hehehhehehhe. pm me for price.
xtremeleo
3,247
464
5,183
or
charging the 4afe up is gonna be a cheaper option, the expense needed to get a 20v cut can e used to get better internals, better turbine, etc.
samuelccy
408
KL-Sentul
I'm always there for 4AFTE & 4AGE 20v!
CEO, mine was finished but not satisfied only ...
Speaking from my experience
BOT on an 4AFE cost much more than 4AGE 20v
Of cos 4AFTE can gives you higher output as it goes by the cost ... you really need to rebuild the based & the internal parts properly before you can upgrade easily without hassle ... BOT on a NA engine is very different from upgrade a turbo-charged engine. It needs a lot of solid foundation before you can upgrade else you'll tend to abandon it after a while. ~ like me :(
you'll never satisfy with the low boost after the amount of money you spent over the power you gained. i.e. 0.5bar ... I thought of that when I opted for BOT over 4AGE but it doesn't even last me for a month with the 0.5bar BOT. The moment you ask for more, it will slapped you with more problems. i.e
slipped clutch (if you're using ori clutch set)
Map sensor (if you're using a ori 1)
fuel pump
boost controller
intercooler
turbine not big enough
lagging
Conclusion
If you want to have hassle free city driving with minimum cost, I would suggest you go for 4AGE 20v but if you don't mind spending more $$$ for better foundation with just 0.5bar with much upgrade potential, then you can go for 4AFTE. No doubt, 4AFTE will tend to fulfills your hunger ... :mad::mad::mad:
Its just my 2cents :idea:
BudakSiol!
181
5
3,018
Veloc,
From my understanding 16V dishes out more low end torque compared to 20V. Also when you say Good Power how much whp are you looking at?
tonyops
249
17
Sarawak
Bolt on forced induction system always give a lot of prob, unless it's default built out from the factory. Turbocharged has more maintenance as well. It's still best to stick with N/A, unless u want a turbocharged system, then go for 3SGTE.
The Marketplace Top Posts
Okay, we all know boring and stroking can add extra capacity to our engines.
One famous kit is the stroker kit. We know just by boring the engine alone we cannot increase much in cc, as the space between cylinders just isnt enough.
On the other hand, if we stroke it, we make the engine a longer stroke engine, therefore at times killing revving capabilities. Engine rebore, however, delays response.
I wanna ask your professional oppinions on this matter.
Is it really worth stroking up the...
