Getting prepared for a race
X.O
Hey guys any tips for a first timer going on a race?
My hatch is completely stock.
Im actually planning to go for a race somewhere early this november but im a little worried my 1.3 fuel injected hatch may face parts wear and tear problem due to old age during the race if i force it too much. But its a race so u gotta drag it alot. Its 10 years old already btw.
So guys out there, feel free do drop advices on what maintainance should be done for my standard engine so that i will not encounter problems later during the race. Do share with me tips for racing too heh.
Please help me out here.
Thanks in advance for advices guys! Have a good day =)
try to play arround b4 u race.. if your confident with your car, then u play.. but if the car is not properly maintained, better dont.. i race and i lost but i happy.. ahahahaaaaaaaaaaaaaaaaaaaaaa..
haha yeah i know i know. I am pretty confident actually. But at the same time i've gotta be aware that my car is pretty old as well as the parts. Things may seem well to do but we nvr know what may go wrong. Old part are still old. They have life spend. Thats what im worried about laa haha.
Well so are up for another race sometime soon? I dont actually care if i lose. Experience is what matters. But my goals slowly laa haha. Thanks for sharing anyway =)
try ask your foreman to check everything.. haha.. done dat b4 as my car reach 6 years.. many part need to replace.. n major overhole.. huhu..tidious..
Yeah i know, thanks =) but sometimes u cant just listen to one person. I would like to gather opinions and seek the best solution hehe. And besides some mechanic may not be very familiar with the smaller part like the parts inside the throttle body(eg: gear inside). And they are likely to be lazy to even open up the parts to identify which part is spoilt when a certain part is filthy. They normally say that this or that is spoilt. Still can use... change it when its totally spoilt. So its kinda costly for me but if there no other solution then no choice lo right haha.
Overhole is a good idea but kinda costly. Im trying weight what else can be done haha. Thanks for sharing anyway dude! Have fun with your ride ya! cheers =)
what race??... drag race??.. circuit racing??...
if drag race, jz make sure ur engine and transmission in good health... learn where is ur max hp/torque in ur rev band so u can utilize it during launch and upshift.... use good tyres and reasonable suspension... play with tyre pressure as it affects ur grip during launch...
if circuit racing, there's lot more to take into concern... engine, transmission, tyres, brakes, suspension, etc... good tyre (semislick preferred), good brakes and good suspension helps alot even though u lack of power.... polish ur driving skill more on how to attack corners with maximum control.... learn where is ur threshold braking and control it under late hard braking....
Thanks skywalker. Regarding suspension, could u suggest an ideal upgraded suspension currently in the market for my 1.3 fuel injected hatch? And also explain to me a lil more about transmission wise. The rest of the following i have done. Its a circuit race btw. =)
ya.. we need to ask many oppinion on that.. eheheee.. mechanic bz? i cant answer anything for that.. if im u, seek for a good mechanic which is recomended by your friend or the mechanic is your trusted friend.. eheheeee.. then stick on that person, like i do.. a fren of mine did all off my car work.. eheheee..
btw, if your saying your driving a stock car, mayb you shoul try to upgrade ur exhaust system and air induction for a starter.. eehheheheee.. later, if u still not satisfied, then u upgrade this and that.. many parts can b upgraded to efi.. but, if you really wana race and be a racer, swap your engine with a really power engine.. eheheheeee.. eheheheee..
---------- Post added at 11:28 PM ---------- 6 hour anti-bump limit - Previous post was at 11:27 PM ----------
bro, talking bout suspension.. wat type of suspension is good for drag and circuit? eheheeee..
1.3 hatch is what car??...
well, there is no suspension which is plug and race... suspension needs fine tuning to match the setting of the car and the circuit u gonna race... hence, best to get high/low soft/hard coilovers.... make sure suspension is firm enough and will withstand the trashing at the circuit....
transmission... get racing clutch plate n cover for a start... oem organic clutch plate will not withstand the punishment of circuit racing... it will soon slip after a couple of laps... of coz there are much more to do, given there is no budget limitation....
bro, in this case.. wat if from changing to racing clutch, change to bigger cc clutch.. like 1.3 to 1.6?
if u can afford bigger racing clutch plate better lor.... coz the material used can withstand higher temperature... it also provides better grip on the flywheel...
Skywalker..
Oh sorry for not mentioning hah. My hatch is a 1.3 satria. Im not very familiar with what type of suspension suits my car best in order to withstand trashing in the circuit just like u mentioned. What suspension would u recommend for this car?
oh btw im actually planning to go for the kampung gajah track race in perak. Are u familiar with this track? From what i heard this track has alot of cornering... err so which set of clutch upgrade would be ideal as well as its approximate cost?
Thanks! =)
Series...
My mechanic is my neighbour so he can be trusted but yeah he has lotsa cars to work on. So sometimes he take the easy way out. He'll suggest use for another few more years till its spoil then nee change. He doesnt really agree to opening up the engine and only repair the change spoil parts. But he's a good mechanic. If budget low he will do the hard job and ask for sometime. So far everything he repairs.. all lasting hah. Unlike all the pther mechanics that dealed with my mum's car.
Oh ya regarding exhaust system, yeah im planning to do so. But exhaust system is a lil complicated. What type of ride are you currently grooming? heh
Anyway thanks for sharing! =)
Skywalker..
Thanks! =)
Series...
ya, exhaust is really complicated.. need to "cuba try".. heheheeee.. currently, using the iswara lmss.. 4g13p wif carbs.. eheheee.. dat why i dont know much on efi.. but bro sky already convert to efi.. u can ask him further as i read his tread and he tapau many of the cars on road.. eheheheee.. sorry bro sky.. :adore:
Skywalker..
Thanks! =)
Series...
i'm not really sure which coilovers suits ur application either... everyone's preference varies alot... to be on the safe side, get aftermarket coilovers from popular brand such as TEIN, HKS or so on...
i've not been to kg. gajah circuit... but as i know its a rather small circuit... close gear ratio will help here as speed isnt important in small circuits... lightened flywheel could help here... the road surface there isnt as smooth as sepang.... so, u might need to set ur coilovers not too stiff or else it will be bumpy at corners... do try out different sets of alignment and camber setting... this could effect handling quite alot....
as for clutch upgrade, can try opt for exedy, trinity or works...
as for exhaust system, since u are setting up the car for race purposes, use 4-1 extractor with 1.8" piping...
Thanks sky! im beginning to understand more and more =)
Could you explain futher about camber settings?
About the clutch on the other hand, exedy, trininty and works are what type of clutch? Are they a bigger cc clutch? And approximately how much is one?
And again thanks! =)
---------- Post added at 05:28 PM ---------- 6 hour anti-bump limit - Previous post was at 05:24 PM ----------
Oh and series, our engines are nearly the same! hah. Just that yours runs on carboratur while mine is fuel injected. I actually dont quite get the difference here. do you?
We can share with each other more too anyway! =)
To make things simple for track days:
There are 2 options for you. The $$$ way and the budget way.
Budget Way:
Make sure no oil leaks. Brake fluid is fresh. Brakes are in good condition and try to use brake pads of higher temperature range. (If you use normal street brake pads) they may damage your rotors if you use them too hard. Recommend you 400-500deg C should be good enough. What brand of brake pad up to your budget...Cooling systems are also important... make sure it does it's job. No leaks and radiator fan working properly. I talk from experience.
Tyres in good condition... semi slicks are rich man toys at the tracks. Also, if you use semi slicks in Kg.Gajah they will wear off very very fast. Give your front wheels the maximum negative camber you can get. At least negative 2deg if possible. Kg Gajah Circuit really demanding of tyre grip during corners.
The $$ Way..
A lot can be done. Coilovers, upgraded bushing, brake upgrades, Engine upgrade.. what ever your wallet can stand you do it and try it out. Hahahaa..
Tips:
Bring extra spark plugs, engine oil, brake oil if you have. Never know when you gotta top up those important fluids. Lots of drinking water. Clear up your car cabin of any things which may interfere your fierce driving. You don't want Snoppy or Garfield caught below your brake pedals eh?
Don't forget safety helmet, shoes and a pair of cool sunglass.
Driving Tips:
Learn your racing line, braking point well. Monitor your speed when entering a corner, example you understeer at 65km/h entering a corner and you spun out.. so the next time try reducing that speed and see if you can control it better. Ideally come into corners slower but you can exit the corner faster.
After some hot laps when returning to the pits, allow 1 lap of cooling down of your engine and brakes before you completely shut it down. heat soak is bad for the engine oil seals. Also do not use the handbrake as your rear rotors/drum brakes are still very hot. They can jam up.
The most most important thing.... HAVE FUN!
Budget Way:
The $$ Way..
Tips:
Driving Tips:
ftzone,
Wow you're making me more and more hooked up to my car haha. Interesting how the lil small details with the budget style can help so much haha. thanks for sharing your advices and experience, ftzone! =)
About the camber, you mentioned that i set a least a 2 degrees negative chamber right? wont the tyre be eaten up unevenly? In this case will i encounter alignment problem in future?
Break pads on the other hand, could u suggest one a few types together with approximate pricing to enlighten me? Cause i just changed my break pads recently but idk what break pads they are. It cost me 85 bucks. its about 2 weeks old only.
Anyway thanks again!
u dont get the difference? means? on carb vs efi or other else.. sorry.. eheheee..
we can share our mode, just thta mine is still standard for road.. no track here in kuching.. theres a track, but supercar plays on that track.. eehehheheee.. just kidding..
ftzone,
If you can drive fast enough at Dato Sagor Circuit, your tyres will already wear off unevenly. Still worry about your alignment? Thats why I suggest as much negative camber you can get. That way you can save a little bit of the outside sidewalls. You can always re-align back after your circuit race for street use.
Since I do not know what brake pads you are using I have no comment on that. If you need better ones, I have 500deg C brake pads for your application for about MYR150.00 a pair. But again, since budget is important this is entirely optional. You can still use your current brake pads.. however you have to feel when you should ease off your hard braking once you have exceeded your brake pads limitation and allow for it too cool down. Otherwise your brake pads and rotors will be damaged. Attached is a picture of my brake pads used in Sepang just for 5 hot laps. I have abused it too much. LOL! Deng .... that pads cost me MYR500!
A thread every 60 seconds
