need help for engine mods in a 4g13p proton saga engine
tofu_manic
1,342
91
5,148
14" inch will be perfect. 15" still ok if u use 50series sport tyres but its not going to be comfortable.
i will recommend 14", coz saga so light doesnt need 15"
Hi there! care to clarify why the lighter a car is the smaller rims it requires?
4g15p, depends on location i think.. alang2, get 4g91.. 1.5 cc too.. i heard this type is powerfull..
Known several forummers who upgraded from a 4g15 to a 4g91, but the power difference vs. cost made it not worth it
what brand hi-cam is better? The adj cam-pulley, use with hi-cam?
used pipercam and matspeed, although more expensive, the matspeed 272 degree cam gave a much fatter powerband, u get a stronger kick in the midrange
pipercam is cheaper, but power gain is not as much, and is more linear, so u dont feel it as much
yeah use adj. pulley with these cams
For more info, do checkout the 4g13/15 modification thread, most of these questions have been answered there
Cheers!
series5401
373
17
Kuching
Cheers!
wat bout jasma?
tofu_manic
1,342
91
5,148
a reputable forummer did a dyno test, there were real gains of about 5-6whp if im not mistaken, and this is a direct drop-in, he hasn't even fine-tuned the cam settings with an adjustable cam pulley, or adjusted the carburettor / ignition timing
series5401
373
17
Kuching
oraite.. tq bro.. thnk wana install it later.. yeahh..
shadow2027
Aug 31, 2010
27
so between jasma, pipercam, n matspeed...jasma better is it? :embarassed:
if know can put up the prices including installation? ^_^
tofu_manic
1,342
91
5,148
erm ive only tried matspeed and pipercam, the older batch of pipercams, im not sure about the new ones
but sure as heck the matspeed 272 ones are worth it for me
jasma, rm4xx
pipercam, rm5xx to 6xx
matspeed / powerzone, rm12xx to 13xx including swapping ur original cams with them
installation costs not included, will vary from shop to shop, not sure what prices are like at semenanjung
series5401
373
17
Kuching
jasma, rm4xx
any shop in kuching selling matspeed? any1 know?
btw, let say adj cam used matspeed, cam used other brand.. good or not with the engine?
any suggested idea on this parts?
tofu_manic
1,342
91
5,148
friend, most of the things that can be done / installed to the 4g1x engine, u have to source them from semenanjung, if people here say they can get it for you, they also get it from semenanjung, but at marked up prices
adj. campulley, u can get any brand to work with any cam (as far as i noe, this is true for 4g13/15 applications)
series5401
373
17
Kuching
yea, semenanjung many items can be found.. here, even weber is rare or i dont got many contacts.. ahahaa.. later planning to go to semenanjung, and ask help from u guys.. heheeee..
tofu_manic
1,342
91
5,148
im from kuching also LAH :P
all you need to do is just look through all the information in the various local forums, you will build your contacts from there and it will be easier from then on, that's what i did
series5401
373
17
Kuching
haha.. same wif me..
ya, tried to seek contacts from forum, but sumtimes feel unsecure as i saw my friend was scammed by sum1 called, i dont remember..
wat car do u drive bro?/ always play at tambak there is it? ahahah..
shadow2027
Aug 31, 2010
27
i'm thinking of putting hi-cam + adj cam pulley to my 4g13p saga or should i change it to 4g15p engine? Which is more worth :hmmmm:
if swap engine, i still use 4g13 gearbox(manual), is it ok? :biggrin:
series5401
373
17
Kuching
for me, if u just wana play2 n enjoy wif ur car, mayb u can upgrade the 4g13.. but if u wana play2 n race with others, u can swap your engine with a bigger ones.. eheheee..
i like to play2 with my car, so i upgrade my 4g13.. eheheeee..
;P
LittleWhiteWagon
1,656
187
P.J
Just remember, modifying your car is up to what you expect...
If youre expecting a big power boost, the 4g13 is really not a place to start, but if youre modding your car just to SS and have fun you wont feel rugi in modding it :biggrin:. Faster isnt always better :driver:
The Marketplace Top Posts
Hi Guys,
Recently I got a pair of Toyota Koito OEM Ballast which originally come with D2 Sockets..
I have done some DIY modification by replacing the existing balast with this OEM on my 9006 (HB4) HID Bulb.. after connecting the balast with my bulb... I was able to firing the bulb but after a couple second it goes off.. I have repeat the process several time and it keep on goes off after firing for roughly 10 seconds...
Balast- Toyota Koito OEM Balast - D2S Socket
Bulb- 9006 (HB4)...
