A32 - 3.0v6 engine jerking
ming_fei
47
Sb3,
So finally how u solve the engine jerking problem? change the injectors (new or used and how much per no?)
or can it be clean?:confused:
sb3
1,141
14
5,138
Sb3,
ming_fei,nope never had a chance to touch the injectors coz i did the engine swap. But I strongly believed 2 of my injectors were stuck open. The spark plugs were (for the 2 injectors) always fouled and wet with fuel.I have swap the ignition coil and plugs a couple of times but came out with the same results (foul and wet). Power and signal were present when checked and the injectors were clicking like normal.The conectors were grounded properly.. Wat else could it be then?
dream.tent
976
24
3,018
www.cardomain.com
Was thinking....Maybe the AFM sending wrong info to ECU and cause the Engine to run too rich?
sb3
1,141
14
5,138
Dream tent, but each time i checked it was always the same cyclinder(s) which are fouling the plugs. If AFM problem, which contributes to engine running too rich it will foul all of the plugs right?
sb3
1,141
14
5,138
o worst case scenario....da 1 wt da foul plug might hv problem wt valve
Yeah i had thought of that too but most of the foreman/mechanic wouldn't recommend valve jobs on the our cylinder head coz its made of aluminium. Skimming the head would warp it. Infact i did check with TC . They told me to replace 2 new cyclinder head (V6 ) as they don't normally do a valve jobs on our cars.
dream.tent
976
24
3,018
www.cardomain.com
Funny...
But for the sake of troubleshooting, why not swapping the ignition coils around and see if the problem follows the coil?
Wonder if there is a way to check each of the injector too. Maybe the solenoid degraded.
cooper1275
1,070
Sb3,
change a set of used ignition coils & leads(6nos all in) from a 2001 accident model, that must have solved the problem,
anyway gys, i have sold my A32 for a good price, and cos i found the car i have been looking, bought a Subaru Sti v8-spec-C,
i will still be contributing/logging in this foum whenever i can, probably bcos i have done alot about my A32,
thanx,:driver:
sb3
1,141
14
5,138
thanx,:driver:
Waaah, Changed your taste to monster power instead of VIP syle ? Subaru Sti is a great and tough car , i wish i can afford one, anyways good luck with your new car!
sb3
1,141
14
5,138
Funny...
Already done that and the problem stays @ the same cylinder/s. All the 6 injectors clicking away fine . (I used a long screw driver and listen to it).
ctk22
129
Bringing back this old thread cos i'm having similar problems lately.
Where is the injector? Kind to illustrate anyone?
Thanx!
sb3
1,141
14
5,138
CTK22, long time no hear fr u. just dismantle the decorative engine cover (which reads Nissan v6 3000...) and there u r , 3 injectors mounted on the fuel railings. That is only the front bank. Repeat the same thing for the rear bank. What do u want to do anyway?
ctk22
129
hi sb3,
i was having the same jerking while idling in gear D problem... and i tried switching and replacing a few ignition coil (trying 1 by 1) but still doesnt solve the problem, that's why i thought of getting a spare set injector from the chop shop and try replacing the injectors see whether that's the problem. That uncle dunno which is the injector and wanted me to point to him. That's why...
Have been busy with work tat's why just left those minor problems of the car unattended. But recently found tat the problems might be getting serious...
weikee
924
15
injector got problem won't be on ideal only. it will have engine "jerking" when driving also. and Plug will have difference color too.
Could be AFM, or vacuum problem.
ctk22
129
hi weikee,
thanx for the info. I've just changed all 6 plugs last week and the wear and tear found to be normal. Thanx for suggesting AFM and vacuum, cos actually i'm having a crack on the air filter box that i sealed it with bitumen. Maybe it's the one causing the problem.
BTW, can I clean the AFM by spraying carburetor cleaner?
Driven: 2012 Porsche 911 Carrera S (991) - CoTY material? We think so!
Time changes everything. A little over a decade ago, I picked up a local magazine and read a review of a Porsche 996 Turbo. At the time, the 996 Turbo was the most powerful variant offered and touted some massive numbers – 420PS/560Nm and only 4.2 seconds from Zerotohundred. I remember day dreaming...​
