87mm vg30 piston + 4D68 94mm crank + stock evo conrod, bolehkah?
jinkl
4,624
376
3,183
Hi all,
Anyone tested the above setup?
Is this the way for makin 2.2L?
What about 4D68 crank with stock evo piston n rod?
Please help.
4d68 crank + evo pistons + rod
ur pistons will be out of the engine block
u would need shorter pistons
11000RPM
954
2
3,018
Johor Bahru
Hi jinkl,
vg30 piston is a shorter piston but i'm not sure anyone tried this b4?
Anyone have vg30 piston specs. I only know the pin size is the same.
yopo
274
25
dear 11 000 rpm..
the combo that u posted were the usual combination used in the lower budget of 2.2L stroker kit..
and it's not a secret anymore on how to make a replacement of ur cc (unless u're willing to go for an ultra expensive aftermarket stroker kits..) :love:
perhaps it's pnp in the evo's block i assume..
what jin meant by using an evo piston in the combo will eventually push the piston out of the block
why not using the thicker 68 conrod as compared with the fragile evo's conrod..
that would be betta actually..
11000RPM
954
2
3,018
Johor Bahru
Thanks Bro Yopo,
4d68 conrod is thicker than evo?
that's great!
BTW, what's the metal gasket thickness required for the setup?
Thanks.
yopo
274
25
Thanks Bro Yopo,
that's great!
Thanks.
i'm using a 1.8mm thickness metal gasket as my comp with the same mention combo is quite high..that's why i'm tryin to counter it
so high boost application and red line rpm's revs amongst the "taboo" for me..just once in a blue moon
why not using a minimum 1.5mm metal gasket at least..
playing with this combo will force you to "gain some but loose some" at the end of the day..good luck :love:
yopo
274
25
there are cometics and tomei with original 87mm bore size metal gasket..
each one suits your budget accordingly...:love:
goo_61t
660
12
go for cometic lerr cheaper then tomei :)
gud luck with ur build 11000RPM.
norick
110
39
hi Goo.. Thanks for ur useful info on phone just now..
Now ill try this 2.2 combo, 87mm VG piston + 4D68 crank + H-Beam Rod(Evo Std size)..
Whats the safe hp zone for max? still below 450? or max 500 ?
For ur ref, others parts is :
- Haltech E6X
- GT30 Ball Bearing
- Jun type Intake + S90 Big throttle
- Port & Polish head
- SARD 850cc Inj
- Walbro fuel pump
- 3in outlet till muffler
What the ideal boost level to set?
gIGoN
327
Hi guys,
i'm currently using a 4D68 crank (94mm), stock rods and vg30 pistons (87mm). If i were to get aftermarket parts for my internals, should i get :
  • aftermarket evo conrods? (eagle, tomei etc.)
  • as for the pistons, I believe i can't use aftermarket pistons for evos as the piston would be coming out from the block, so does this mean i have to get those only from vg30s? any other models?
please help as i'm thinking of changing aftermarket parts for my internals for safety and reliability.
11000RPM
954
2
3,018
Johor Bahru
Hi Bro,
What about stock 4d68 conrod?
It's bigger than vr4 ones, what i worry is the rod weight. It's heavier, can the bearings tahan or not?
4d68 conrod pinsize is 23mm, need to use bronze bushing, is it reliable??
gIGoN
327
i wanna use aftermarket parts bro, not oem parts...
so i wanna know wat aftermarket rods and pistons could be used on 4d68 crank on an EVO block...
jinkl
4,624
376
3,183
u can alwiz use crower , brian crower , pauter , carillo , scat, eagle n all the rods
only thing u have to custom would be the piston
Eagle Stroker is 94mm , but 4D68 is 93mm , u have CP 94mm stroker pistons, bt if u fit them to ur car , u will have low compression cos its 1mm below the deck
gIGoN
327
jinkl, so u're saying that i could still use any aftermarket evo conrods but the only problem is the pistons?
should i get aftermarket pistons from the vg30 shelves? or if you know any aftermarket pistons which we could mix n match for this combo please let me know.
As an alternative, let's say if i were to install the CP stroker pistons (for 94mm application), could i compensate the metalgasket size, maybe we could -1mm from the gasket, eg: usin a 0.5, 0.8mm metalgaskets.
jinkl
4,624
376
3,183
u could buy custom pistons from wiseco or manley
try contacting this guy , Log masuk | Facebook
he is the one hooked me up with a custom wiseco
so u could just use a piston spec meant for 94mm stroker and just custom the piston pin location to move it down by 1mm , it should be much reliable than getting VG30 pistons n etc
11000RPM
954
2
3,018
Johor Bahru
Jinkl,
Have u encounter anyone using 4d68 conrod?
Its thicker but need bronze bushing, is it reliable?
According to my mech, it's much better.
The duratech conrod comes with bronze bushing isn't it?
I'm trying to save money lo, I'm trying to measure $/hp, kekekek...
gIGoN
327
anyone knows what's the stock vg30 piston height / comp height?
gIGoN
327
got it...it's 32mm so i believe i found the aftermarket combo which i would use.
1. Wiseco off the shelves VG30 pistons 87mm bore / 32mm comp height
2. Any off the shelves EVO conrods (Eagles, manley bla bla ) 150mm
3. 4D68 crank 93mm
Given that the std deck height is 229mm the setup above will yield to:
93mm/2 (crank) + 32mm (comp height) + 150mm (conrod) = 228.5mm which i would assume it would still be below the std deck and is safe to use wif a 1.5-1.8mm gasket.
I would say that if you're using an aftermarket 94mm crank, you could add in a thicker gasket, maybe 1.8mm - 2.0mm.
Sifus, correct me if i'm wrong somewhere hehe..
HELP NEEDED
Halo frez..any1 out there can help me with some engine advices. 1st of all i wana kno is there a mivec engine wit turbo, to my opinion there is 1 but i'm not pretty sure..if there is 1 can i know wat it is name and its specs?
besides tat i oso wana know wat engines tat can be transplanted into my wira 1.5AT other than GSr and GTi..i'm basically interested in VR4 engine wit TD05 turbin..but i'm afraid it will give me problems in terms of JPJ matters...
