WTA:BT 20V engine noise
YUZZRAY
138
KAJANG,SELANGOR
I just swap my engine 4A-FE with BT20v.. The problem is,in the morning, when in cold start the engine runs very quiet.. But after the temperature alredy hot, it start making noise like 'taxi diesel engine'.. why?... anyone facing this problem before?.. is it because of the type of engine oil that i'm using?.. (rm55 WIN brand) or my engine got a problem?. any suggestion from all sifus here?...
banzai
1,231
29
5,148
KL \ Ipoh
dun worry, it's normal. it's the intake pulley sound. usage of good oil can reduce it, but will not eliminate it. WIN brand? at rm55, i suppose it's mineral based?
suggest u use at least semi-syn from reputable brands such as eneos, pennzoil, Q8, motul, and others. check older threads on feedbacks from fellow forummers on the types of oil they used. it has been discussed for some time.
nappx
2,532
185
5,163
kLaNG-kEy_tEE
change to adjustable campulley. & used good reputation oils...such as Motul, Q8, Eneos, Torco...
jack84
183
ya, change both of the cam pulley to adjustable 1. It can eliminate the "diesel sound"
Btw u can also gain abit power and respond for ur engine 1 stone 2 birds ...i am sure u will like it ! :biggrin:
banzai
1,231
29
5,148
KL \ Ipoh
correct correct correct.
jack, i heard your engine now sounds like subaru wrx already? hehe. some says sounds like high cam also..:)
YUZZRAY
138
KAJANG,SELANGOR
TQ to all sifu.... one more thing i want to ask..I'm using oil temperature meter.. when in high rev, the temperature goes until 130 degree celcius.. is it normal?..
chinozie
Very Young Member... :D
3,429
170
5,163
Damansara
4age20v.blogsome.com
1) service your VVT pulley...will eliminate the diesel sound...FYI new VVT pulley cost around RM800++ ...
2) Check water pump healthiness, Service your radiator...if using toyota coolant or other coolant do change after runnin few hundred thousands km...
Good luck...
banzai
1,231
29
5,148
KL \ Ipoh
1)
Good luck...
wah boss...few hundred thousands km ar?? bisnes lingkup la like dat...lol. i think change once a year or two is okay. afterall the coolant is only abt rm20.
yuzzray : if sepang u whack 8k rpm for a few laps, oil temp will hovers around 130-140. in street if whack 8k rpm once a while, it normally not more than 110. This temp is without oil cooler. so think yours is not normal. and what oil temp meter u using? electrical or mechanical?
YUZZRAY
138
KAJANG,SELANGOR
yuzzray : if sepang u whack 8k rpm for a few laps, oil temp will hovers around 130-140. in street if whack 8k rpm once a while, it normally not more than 110. This temp is without oil cooler. so think yours is not normal. and what oil temp meter u using? electrical or mechanical?[/QUOTE
130-140?!..thats out meter meh.. I'm using omori oil temp & oil press meter.. item comes with Halfcut.. just PNP.. Lucky me ne...:burnout:
never using this before.. just too afraid engine kong only.. he..he.. what type of engine oil that you use?..
jack84
183
ya...just like the high cam..:biggrin:.
i think need to retard the pulley ...cos advanced too much.:hmmmm:
The power from 3k-7.8k all the way ...
Now my car fuel consumption super high.... like drink water ....
Lolz....banzai change ur pulley to adjustable 1 la seem ur sepang kaki:biggrin:. I heard tat still got1 set at choy there...:biggrin:
banzai
1,231
29
5,148
KL \ Ipoh
hmm, omori meter. good stuff. like i said, try use better oil. i'm using Eneos semi syn. if u dun mind higher price, go for Motul.
YUZZRAY
138
KAJANG,SELANGOR
Bro nappx, how much cost that i have to pay for adjustable campulley?.. any lobang for a good and cheap one?...
nappx
2,532
185
5,163
kLaNG-kEy_tEE
ok..where to get campulley? i throw question to u back...what brand of campulley u want? if aerospeed or others brand except toda...you can get at any performance shop at sunway..
but for me go for TODA.
nowdays difficult to get toda part..not many shop keep stuff for 4age/20v. 3weeks ago..i search one to one shop at sunway...no stock...lastly i call kegani..yes..he said got for BT..but when i went there, he forgot to update their inventory..no more toda adjustable VVT pulley for BT..only got for SVT..nevermind la...still can use...but for exhaust i think still have few...but until today..don't know la...he bring new stock or not...
so...up to u..got extra money..go for toda for more realiblity & got value for second sale..he he he...
YUZZRAY
138
KAJANG,SELANGOR
For me money is no.2.. the first thing is if I change the campulley to adjustable one, is it really can reduce the 'diesel engine noise'?.. If can, then I'll go for it.. thx to all the sifu for your suggestion..
Hie...
im new in engine mod. if any forumer have advice for me regarding 4G91 engine.
I've realy have tight budget and need to replace my current engine. Stock engine has blow last saturday night and i want to do transplan in this week.
by the way... im driving Mitsubishi Lancer A172 (Lampu Kotak one), Rear Drive and and my stock engine is 4G12 (1.4cc SOHC)
i ask mechenic and mechenic told me that i can use any 4G engine < 1.6 that should ngam with my gearbox.
i notice that 4G91 has 2...
