Sagawara 1.3 minor modification
Greetings everyone...
i'm currently driving a '03 manual Iswara sedan.My engine setup is like this:
4-2-1 extractor with stock piping,infinity swirl centre bullet and Pro1 muffler
open air filter with aftermarket intake pipe with cyclone device
HKS voltage stabilizer with 6-point grounding wire
if anyone can suggest to me anymore minor modification can be done to increase the engine response??is changing the piping to 2" size is good??or sumthing wrong with my setup??
feel free to comment here,any opinions will be highly regarded
JasonKam
103
6
Tmn Kinrara S'2
bro,1 3/4" inch piping is suitable for ur car.....if u use 2" piping,it will drop down ur performance...change ur spark plug and cable too...it will give u better response....check ur center bullet,r there in correct place? and the piping after center bullet.....
fstr
7,935
954
Sahara Desert
use 2 inch piping for 1.3 will drop performance?
wow.. din know that :biggrin:
what should i use then? 1 inch ok ah??
MingFai
417
25
P.J Jln Gasing
eh dun teach bad kids ler... said real de... ppl ask very sincer asking for da answer la Moderator bro!
DanzEterna
15,911
3,371
www.primeperdanaclub.com
i tot its 1.65 or 1.68" for piping....
1. CAI (cold air intake)
2. NGK racing spark plugs or denso v racing rm350 for 4 pcs....
3. surbo..haha worth trying...
MingFai
417
25
P.J Jln Gasing
put 3 inch more power more better....
wa the spark plug saga also need rm350 wor geng guai
nurburing
271
if outlet pipe size is 1.75 inside actually is 1.68inch only, if 2.0 inside is about 1.93inch.....if weber + highcam 260 or 272 use 2.0 lor
fred, u oredy expert play 4g15 maaa.....still want change meh
i have a question is ..currentlu ..
i have installed a RSM in my car ..and when im on IDling my rsm can go to 4-11k rev on it on self while my car is not movin ..
and the Speedo meter that i running on KMPH and the RSM is not moving ..
i have fix the RSM on Sunway AMoil ..but they said is my wiring problem..im using VR4 engine with original ECU ..double check of Wiring connect to rsm..and there is not cut off and etc..
what the meaning of Output Select in RSM SP1 ?
what is Sp0 /...
