How to improve my car...B20b vtec.
hornydrifter
837
90
3,028
KEY EL!
Hi there,
To all the B series sifu's out there...Please help me out...first let u guys know's my car spec.
Honda ef9.
B20b 86mm X 89mm (DC5 pistons)
Custom sleeves with supertech block guard.
carrilo conrod.
Full balance on all rotating anchileries.
Skunk 2 intake with super90 70mm.
Cometic gasket 0.6mm
H22a injectors.
VAFC tune onli (money finishing).
NGK cables and plugs.
MY HEAD spec..
ALL STENDED..SMALL V head. with skunk 2 tuner cam pulleys.
Clutch ACT.
Now my car dynoe'd at 202hp@7600rpm sumthing2 and torque at 22kg/cm.ALL at the wheels hp. (Dynoed at jacky's)
My aim..gaining [email protected] playing cams..
Im trying to playing "efficiency", rather than whack sum cams and see BIG HP"s...Im no that person.
MY questions are..do ignition play a big part on this?
2nd...
Regarding the HYTECH headers and shit. heard the tuned runners are mathameticlly calculated to get the best hp and torque..Or there's any better out there? My fren using on his b18c stock... 177hp using this get 189.22hp...Huge gains...But the cost of lotsa $$..(i'm using tonnka type 4-1)
To all sifu's are the any point of changes to mke more power rather than cams?
Such as decreasing the frictions and stuff..
Any pointers will be greatly appreciated.:driver:
akuma
3,489
152
Kuantan
dun mind me asking,who built ur engine?w 86mm DC5 pistons(hi comp oredy!) ur only getting 202whp n 22kg/m torque?w all d goodies in ur engine,u SHUD b pumping 230whp @ least!
but thn again,u mentioned everythg else is stock standard,so i assume no head job was done n ur running stock B16A cams.well,wat do u expect?w d stock cams,der's only so much air dat's being drawn into d combustion chamber......
it'll b tough if u dun plan 2 chg 2 high cams....head job might net u ard 3-5whp...dat's all it'll go....n yes,d Hytech header WORKS..even d replicas....haf a few frens using 'em pumping in excess of 240whp(84mm n 85mm pistons).......
hattech-v
Over 10,000 RPM!
12,756
12
Seri Kembangan
www.avantech.com.my
do the head job... pnp, valve angle job etc.. it will produce better hp...
nothing much ignition can do to gain more hp...
but to make it 220atw, high cam is compulsary...
and one more thing, get standby with oem head gasket n bore it to 86mm... it last longer than cometic... :)
hornydrifter
837
90
3,028
KEY EL!
Only the blocks are fully loaded...the rest pretty much stock~ includes the head work. Nasty's head job...let say..if a really good one...flowing 240cc air flow per port will it give good power?
How much is the hytech...heard it its around 1700 siap pasang..AND that's only the replica's~
---------- Post added at 12:05 PM ---------- 6 hour anti-bump limit - Previous post was at 12:03 PM ----------
HAAAH? Y is it will last longet than comatic??? dun make me scared la bro..driving around with 86mm daily already like driving on time bomb~ (like jacky's said)...hahahaha!
ANY MORE POINTERS OUT THERE?
akuma
3,489
152
Kuantan
hornydrifter,
owh..4got 2 mention..all my peeps r using d Hytech REPLICAS..not d original item.....n yes,they r still pumping in excess of 240whp....even a fella w basic 84mm B20 set up netted 215whp....
hattech-v,
dun mind me asking....r d cometics reallt dat lousy or only recently?coz i heard d market is now flooded w fake cometic headgaskets too....
hornydrifter
837
90
3,028
KEY EL!
Aiyo....comatic also got fake....1st the skunk intake, then this...after this wat? fake race fuel?
BTW....the b20 84 mm netted 215hp??? wow..thats high~ stock arr bro akuma? or got sumkind of 'hantu" innnit?
akuma
3,489
152
Kuantan
hornydrifter,
eh,sorry....it's a 85mm Wiseco.....stock bottom....high cam n "massaged" head....it's d other 84mm CF4 pistons equipped B20 dat's pumping in excess of 240whp...hehehhee.....so,r u gona go high cams now?
LuKa
618
19
Kedah
r u running on cable type V-Tec? since u mention bout small V... suppose to be on EF9/EF8 Models
camshaft
411
10
change to b16b cams...still OEM :biggrin: can get bout 7-8HP
hondata maybe? another 7-8HP
already 220HP :biggrin:
deacon
Senior master debater
1,167
30
Swap the header for hytech, toda or SMP (spelling?). Check out honda-tech.com. Most of those fellas there swear by the new long primary design 4-2-1 headers. But be advised, it is freaking expensive.
deacon
1,167
30
Sorry i meant SMSP header. It's about the same as the hytech ones i think. Search google images.
akuma
3,489
152
Kuantan
look awfully similiar 2 Hytech's unit.who copied who?ahahhahahaa...........
anyway,searched ard n found d header test done by d hondatech guy...
m surprised Hytech actually netted lower torque compared w d OEM header?
TEST ENGINE:
JDM B18C Integra Type-R STOCK
PLACING:
1st RMF NARROW 4-1 185.61whp/128.49TQ
2nd SMSP Prototype 4-1 184.70whp/128.98TQ
3rd SMSP 4-2-1 182.38whp/123.82TQ
4th ANR w/Merge 181.05whp/125.79TQ
5th DTR B-Unit 180.82whp/125.46TQ
6th Hytech Production 180.63whp/124.19TQ
7th DC JDM 4-1 174.24whp/124.04TQ
or they only work best w modded engines perhaps?
AD_EG
6,328
231
Ipoh
brother horny,
nice build you got there...
Why not go for b16b cams? at least something also right? +with PNP + with hondata like bro camshaft mentioned .... if you + with tat header i think its safe to say your are hitting your target figure.
Good luck bro.
The Marketplace Top Posts
This morning, one of our members' Satria GTi had been stolen in mutiara damansara area...
the car was parked in the compound of an apartment...
Forumers, please help us keep an eye out for a turbocharged satria with an original GTi outlook and paint (with black front hood and dark rims) which bears the FUZE PROJECT sticker on all windows...
