reflash ecu or use e-manage?
ce9a_evo
93
2
1,508
I'm using evo 6 stock engine , and i've 1 e-manage on hand .
currently planning to set ecu , either to reflash / re-map stock ecu better , or install the e-manage to tune better?
can sifu here giv some opinion?
jinkl
4,624
376
3,183
i would go for reflash as u can map the whole ecu and not just a few points
summroe u can lift the boost cuts and rev cuts off the ecu
i tink u have to explore www.evolutionm.net , lots of info
chrissyong
975
14
do two together is nice,but use stand alone ecu is better!easy and freedom and faster~
ce9a_evo
93
2
1,508
thx jinkl . lots of info there ...
jinkl
4,624
376
3,183
Interesting Q, I also would like to know
not all of cos :D
depends on the ecu , and if someone has reverse engineered it and made a software + hardware to flash the original chip
rechip and reflash is not the same
redmark
19
Interesting...newbies here..would like to know more...which one better..ECU reflash or go for e-manage?
evo_kaki
47
5
1,508
just got my ecu reflash .
Setting include remove speed cut, rpm cut, boost cut and also tunning for air fuel & ignition timing .
Satisfied with de horse power came out from stock engine , but not satisfied with the price to reflash which is high.
teztozterone
381
Hi guys,
What ecu are you using bro evo_kaki?
I have an evo 2 stock ecu...don't know whether to re-chip it or to get an emanage.
I know a chip will remove all the cuts...but will it be able to be tuned to the mods on the car through the chip?
Like how an emanage will be able to be tuned...
Any feedback will be appreciated.
Thanks all.
kumar22mostwanted
1,562
152
HELL!!!
Hi guys,
Thanks all.
i also would like to know about this whether to remap or just add piggy back or change to standalone
any sifu here please help :adore::adore::adore:
foofis
119
7
Johor
reflash ecu + emanage is still alot cheaper than standalone. as long it do the job and give you desired engine respond n power is good enough.
kumar22mostwanted
1,562
152
HELL!!!
this also depends very much on ur engine and mods setup
if lighltly modded or stock i was advised by many sifu that remap the stock ecu is dam good already
i myself prefer rechip/remap coz ur retuning the whole ecu to the exact preference of your car coz ori ecu will sure be set to run more rich from factory plus when we start playing around with exhaust , air filter and other mods we definitely wont be getting the optimum a/f ratio to derive the most efficiency out of our engines that why i feel remap is better
coz piggyback has quite a bit of restriction unless u use like emanage ultimate lah where it has a huge base map
jinkl
4,624
376
3,183
if someone doest ecu reflash or rechip , then on top of it he uses a emanage, it means he is using copychip and not a custom chip, dont kena tipu bro, in other words he know nuts about rechip/reflash
i was wondering, what kind of gearbox those lancer are using with vr4 engine under the hood runing back wheel drive? what kind of gearbox can the vr4 engine merge with so that its rear wheel drive? for those who still heard the beast van which using vr4 engine under the van which produce 400++ hp...
how they manage to merge the gearbox? what gearbox ohhh?? :blink: fascinating to me... show me the reality?? anyone??
