CPS (Cam Profile Switching) vs VVTI vs DVVT
sphiroth
103
5
3,018
NGV....is it safe and I know that not many places have this now.
Its safe as long as it is installed by the authorised workshop and using authorized tanks. The one that blown up last year is because the owner use LPG (cooking gas) tank which cannot withstand high temperature inside the boot. Yeah, to get re-fill is a problem.
Jan 18, 2010
all Land Rover 2010 are using new engine which is the 2010 version engine. and all these engine equip with CPS (camshaft profile switching). this include the RAnge rover, Discovery and freelander. just go surf the web typin land rover 2010 + CPS. have fun!
boyzone
2,669
5,148
I think I will hold for my CPS first as waiting for turbocharge version. :biggrin:
sphiroth
103
5
3,018
I don't think they will come out with CPS-T because it is more complex to tune/design a turbocharged engine with valve lift (mivec, vtec). Even Mitsu only got it working in EvoX. Most probably they just use the non-CPS campro for turbo.
hachiroku clan
633
73
for land/range rover, its Crank Position Sensor bro.. Not CamProfileSwitching..
estear
From Facebook
Jan 11, 2010
16
1,503
Not according to landrover:
The new LR-V8 Petrol Engines feature:
• An improved six-speed automatic transmission tuned to maximise performance
• CommandShift® for better response and smoother gear changes
• 'Drive by wire' throttle control and camshaft profile switching
• Dual Independent Variable Camshaft Timing system (DIVCT), an industry first
http://www.landrover.com/int/en/vehicles/range-rover/features-and-specifications/Engines.htm?page=2
boyzone
2,669
5,148
Non CPS campro with turbocharge also can .. :biggrin:
But, is the improve version from campro 110 bhp engine.
If not, engine will not last for 100k km.
hachiroku clan
633
73
Land Rover International - Features & Specifications - Engines & Transmission
Like vtec, vvti,dvvt.. They are all known as cam profile switching.. In this case, its DIVCT.. Only proton uses the term cps.. I thought land/rover using campro engine! Hahaha my bad..
estear
From Facebook
Jan 11, 2010
16
1,503
I beg to differ...DIVCT is related to the timing of the cam, regulates/times how the cam shaft rotates (cam phasing) whilst CPS actually shifts between two different cam profiles like VTEC, VVT, MiVEC etc. (cam shifting) CPS is a Lotus invention, whilst VTEC is Honda, MiVEC is Mitsubishi, VVT is Toyota (two types, cam shifting and cam phasing)...so nothing to do with Campro except that it uses it...
hachiroku clan
633
73
i know, but isnt DiVCT (dual independant variable camshaft timing) almost the same as the others? I mean i has dual profile too right? This land/range rover has CPS and DiVCT.. How is that? Im confused..
Btw this was what i meant the 1st time: Land Rover Crank Position Sensor - Engine CPS - Bosch - PartsGeek.com - Discovery Range Rover
estear
From Facebook
Jan 11, 2010
16
1,503
dual here does not mean dual cam profiles, but rather dual cam shaft - it regulates timing on both intake and exhaust cam shafts. Cam phasing VVT regulates the timing of the cam rotation, say by advancing the cam rotation by 30 degrees to allow earlier intake during high speed. The cams on this VVT camshaft may be single cam profile per valve or dual cam profiles for cam shifting.
The land rover engine has both cam phasing (DIVCT) as well as Cam Profile Switching (CPS) on the intake camshaft and exhaust camshaft...
hachiroku clan
633
73
Ok i get it now.. So its 2 diffrent thing.. Hehe thanx! Its good to know.. Btw saw the link? Thats what i got when i googled for it, and caused the confusion for me.. Hehehe
GSR06
455
17
I think that way too...but you need to maintain the turbo ler... my TD04 is dying...do you know the market price for a TD04 now?
---------- Post added at 07:44 AM ---------- 6 hour anti-bump limit - Previous post was at 07:42 AM ----------
So, in other words, the technology is more advanced in land rover...price is also higher:biggrin:
hi guys... what oil catch tank use for ? .. i ask many times before. no 1 reply me..... so ask here...... once again ...
thanks
