High Camshaft 288
93na
597
20
than go for matspeed bro!!! not bad for th price u pay!!!! was using on my previous ride!!!!!
darrengoh89
222
if i get a performance camshaft ..of coz i'll need a ACP ...but without any ecu management on my svdo ....will it works as well ?
93na
597
20
eeeeemmmmmmmm that i m not sure!!! sifus out there!!!?????
aminnorrashid
23
i used 288 camshaft on my rvr engine. using afc neo and adjuster pulley. but i think it need modification on block, piston and head and also good tuning. who want to trade with lower degree cam like 272 can contact me. this 288 cam from mat speed and can use in evo1-3 or vr4 engine. sorry to rapped this thread
protonevo
247
3,018
Selangor
www.zerotohundred.com
Actuall after changed the Pipercam and standalone ECU. The car really can feel the deference. Please be in mind car go faster means consume more petrol . So please take note on this. I agree with aminnorrashid engine need proper balancing and tuning the the high cam is the way for NA. Sad lah my car got knocking sound if I drag too much, looks like I need engine balancing soon. 288 really power !
joe_mirage
1,030
44
1,648
rotationperminute.blogspot.com
got knocking ? better tune your standalone. knocking can kill your engine. btw last time i used matspeed 272 cam in my 93. all i can say. power wise. lot of torque. fun to play with but very hard to idle especially when i open the aircond. need to have ficd.
SkYwAlKeR
Over 10,000 RPM!
10,146
300
5,183
ePoh ~ malacca
hmm ...if im low in budget ...izzit should i go for pipercams 272 degree ?and how much is it ...
yeap... local pipercam spec is about 272 degree... cost approx rm550...
---------- Post added at 05:30 AM ---------- 6 hour anti-bump limit - Previous post was at 05:29 AM ----------
yes..
Enslaved
226
The LT10s with a good tune will boost power/torque substantially. Have a mate with 288 cams (matspeed regrinds), PnP, high comp, big bore (1.9)..pushing 190 whp, 200 was possible but gasket was not holding up.
ftzone
full throttle zone
5,339
141
Penang, Prai
www.ftzoneracing.com
I believe for 4G93, TOMEI camshafts has the highest lift compared to any competitor.
Therefore for MAX performance out of your camshafts the best choice for now would be from TOMEI.
Duration alone is not everything...
eg. 270deg with 11mm lift would perform better that 272deg with 10mm lift. as the valves opens up higher, therefore having more air/exhaust into or out of the combustion chamber. just make sure piston to valve clearence are met.
joe_mirage
1,030
44
1,648
yups very true but tomei is not the only camshaft that offer the higher camshaft lift + duration. there is also RPW Australia. But the price of RPW cam is too expensive! most people cant afford that. For me, Tomei is the better choice for power + price since it comes with hardened valve spring. i'm also planning to change to Tomei soon after my new cylinder head finish PNP and my pocket is full. lolx
Shinjite
864
120
Klang
I'll be gunning soon for a 288 matspeed cam with ECU tuning + B series intake manifold mod
Can't wait for it, but don't know whether my current exhaust setup can take it or not :)
zac
1,347
231
Johor Bahru
Tomei also made cams for mivec gen1? how much and whats the spec? interested... i thought only jun, rpw and some local shops make mivec cams... : )
joe_mirage
1,030
44
1,648
gonna be a screamer! btw maybe can change your current header to 4-1 type or cusco 4-2-1 or maybe custom spec follow the bisimoto design? hehe. i've seen one satria during
SDB with custom bisimoto design header. very tempting! with 316 cam regrind by matspeed in his 1.8 SOHC!
dun have any idea about it but when i checked on the website they don't produce any camshaft for mivec 4g92. correct me if im wrong.
93na
597
20
Quote:
i know that car!!!!! green right!!!!!
Shinjite
864
120
Klang
I'll opt for a custom make 4-2-1 header :)
9000 rpm should be good eh :D
A Post Every 5 Mins
i want to convert my PCD frm 110 to 100.
how is it done?
i've been told to change my whole knuckle in front and hub behind.
but what about conversion without resorting to those options?
