tqtq bro.....i know where is AH Heng exhaust area...is near the giant USJ rite??thanksif you do need to drill a hole. get a machine shop that has the right tools. ie. milling machine. at least then you can get the PCD you want drilled at a 90 degree angle which would ensure your new replacement studs are press fitted in properly and will maintain more or less perpendicular to the hub. avoiding headaches later on when you try to fit your shiny new wheels and realize one of the studs are not perpendicular. you'll really be regretting and scratching your head if you encounter such a problem. :)
off the top of my head, i notice at least a dozen machine shops around subang industrial area. the area where AH(Ah Heng) exhaust is. just drive around, you'll notice signboards that have the words 'Engineering Works' or something similar.
Thanks for telling.......found it last weekend but most shops close....will go there during weekdays....:_:blackhowling,
exam period this entire month that's why no updates. but do stay tuned as the bodywork is APPARENTLY ready by next week...although i'm already bracing myself for more disappointments.
ae101rulez,
at the crossroad (left summit back entrance, straight is giant) go right. go all the way straight till u pass another crossroad, then turn left. go straight and explore the area. you should see a lot of accident cars and stuff lying around.
