4G67 Block and small modification for AWD.Only for fun.
Spec engine
1.Custom Intake Manifold
2.HKS fuel rail
3.90mm Throttle body
4.Solid lifter
5.290deg custom cams
6.CNC Aussy Head Work
7.Oversize 1mm valve
8.Performance Valve and Retainer set. 11000 rev
9.SCR Custom rod
10.Wiseco Pistons
11.SCR Stroker Crank
12.ACL Race Bearing
Force induction
1.Custom Billet Turbo
2.Custom Turbo Manifold
3.Ceramic Coating
4.3.5inch down pipe
5.TurboSmart Waste Gate
Fuel and Ignition System
1.Haltech Platinum 1000
2.5 bar map sensor
3.1700cc x 8pc injectors
4.High performance Fuel Line
5.Aluminum Fitting
6.Aeromotive 1000cc fuel pump
7.SCR custom Surge Tank
8.TurboSmart Methanol Fuel regulator
9.AVS spark Plug No 9
10.MSD 8.5 helicore Plug Cable
11.MSD Ignition Coils
12.65psi Turbosmart Boost Controller
Cooling system
1.APEXI Intercooler
2.3.5inch Intercooler piping
3.Turbosmart Blow off
4.Aluminum Radiator
Transmission
1.DOG Gear
2.Ikeya Formula Shifter
3.AWD Manual GearBox
Hp Rating
1.750whp at 1.8bar
2.850whp at 2.5bar
Fuel
Running E85 (Ethanol)
Thanks to
Sport Compact Racing
Spec engine
2.HKS fuel rail
4.Solid lifter
9.SCR Custom rod
10.Wiseco Pistons
12.ACL Race Bearing
Force induction
3.Ceramic Coating
4.3.5inch down pipe
2.5 bar map sensor
5.Aluminum Fitting
Cooling system
1.APEXI Intercooler
4.Aluminum Radiator
Transmission
1.DOG Gear
Hp Rating
1.750whp at 1.8bar
2.850whp at 2.5bar
Fuel
Thanks to
