b16b wiring from ek9 dashboard?
spring
146
69
Jitra and KL
i convert my civic so4 99 auto to b16b type r year 2000 package including ek9 meter. but when the mechanic do the wiring works, he asked me to buy ek9 dashboard because he told me that there is one more wiring socket to be installed from ecu to the dashboard itself. is it true? for the information, i've changed my original so4 dashboard to dashboard with digital view for aircond panel. is there any other solution to overcome this problem?
Hikaru
3,665
22
Atlanta, GA
photobucket.com
The wiring of digital climate control has nothing to do with the wiring on engine parts.
The problem I can see is the main harness running behind the dashboard. It's the main harness coming from the main module under your dash. I think your mechanic found missing sockets from the meter, the 2000 ek9 meter has ABS sockets which your local chasis doesn't has. I don't think it's an issue at all unless you want to run ABS with your car.
spring
146
69
Jitra and KL
so thats mean i can still use my own dashboard running with ek9 meter and b16b ecu?
E-Tech
1,115
256
3,183
Johor
Bro...
EK9 year 2000... ECU OBD2B...harness...
You are "missing" which connector? ... this is the ecu diagram pin out
TQ
addtional....
Reconfirm.... your ecu from top 1 or 2?
1. OBD2B
2. OBD2A
3. OBD1
4. OBD
i install gab ss series about two year, after i install ss series, it got a sound kakakakak............. come out from my car left suspension area,
i try to repair, take out-install many time, change mounting, send back to gab sevice center, but result come out is same, who people face a same problem, or which shop can help me to solve the problem????
