Accord CL9
Muhammed
121
74
www.dezignercustoms.com
Ok so you are Upgrading from Just Using a Lowiring Spring to A Adjustable Spring and Damper kit , What would a Kit like that Cost , and The Place you are buying them At , Do they Stock Tein Lowering Springs , Tein do make Lowering springs too , that are Similar to Eibach , But not Sure on the Cost
kimae
37
2
1,508
Subang Jaya
hi fellas....
my K24A engine still got the speed limiter. Actually, plan to use Pivot Speed Meter V to remove the limiter function but unfortunately it's not compatible for K24A, it could be installed for other function except for Speed Limiter Remover....aiiyyooohhhhh :banghead:.
Got any idea how arrr??? Cruising a 2.4 engine on a freeway with maximum speed 180kph is really2 unacceptable u know...hehehehe!!
EGK20A
86
7
1,508
Maybe your choices are down to HKS SLD [ Speed Limiter Defencer ] and Apexi RSM [ Rev Speed Meter ].
kimae
37
2
1,508
Subang Jaya
Yeap....HKS SLD Type 1 but still trying to locate the dealer. Checked with JRacing, N1 they got no stock, Kakimoto still checking. Where else meh??
Another thing, if use HKS SLD...meaning that I still need to add additional speedometer aite? Or could it be connected to Pivot Speed Meter??
kimae
37
2
1,508
Subang Jaya
Or you can get a Good tuner , and a piggyback Chip , like Dastek UniQ , Or any Other and have no Limiter as well as Much more Leeway to extract Power from that K24 by Fine Tuning
have u done it muhammed?? if yes, how much it will cost me, and where??
Muhammed
121
74
I have not Done it , But have friends Some , Have Used Piggybacks , and Some Standalone Management , They Did Manage to extract more power from the K series , In Malaysia However , Dastek UniQ is available , But who stocks it and where to Tune it , that I cannot Answer at Present , But I am Pretty sure Someone on the Honda Forum can give some Guidelines
kimae
37
2
1,508
Subang Jaya
guys.....
i've checked already, got two option on how to remove the limiter for the K24A;
1. RSM - by right, the diagram didn't mentioned that the RSM could function well on K24A, however KakiMoto & JC Racing claimed that they've done it before, they know how to manipulate and configure the RSM to work for the engine.
2. HKS SLD + Pivot Speed Meter - HKS SLD clearly mentioned it will function well with the engine, however since the SLD doesn't provide speed indicator, it require connection to Pivot.
The cost for both method is about the same, it just that option 1 is a self configuration by the mechanics and the option 2 is a factory setting.
Any opinion?? :smokin:
bien335
1,819
48
1,648
Johor Bahru
I had a chat with Tony from SHC ( I think his name is Tony, since he has an SHC sticker with the name Tony)
We were chatting at Ah meng's tyre shop, and he said that the best method to remove the limiter for the K-series is by using Pivot Speed Meter. he didnt mention about using HKS's speed limit defeater though. just the Pivot Speed Meter. a much cheaper option compared to Apexi's device.
He drives a CL9 TypeS (with TypeS badge at the rear) which I suspect is an Aussie model, since the car doesnt have HID.
kimae
37
2
1,508
Subang Jaya
bien,
i wish u could find out more from this guy tony. I've checked with 3 major places at Sunway, the Pivot Speed Meter won't do for K24A. It's definitely cheaper but since nobody could give any warranty on that, i'm rather not doing it.
thanks anyway...
aja
4,696
35
5,148
hehehe.
K24A guys really hard-up for the speed-cut arhh..
Drive slow2 brother...dangerous on careless speeds. hehehehe
kimae
37
2
1,508
Subang Jaya
hehehe.
have to la aja, idak kalu kennot keep up ngan hang mase TT nanti....hahahaha
bien335
1,819
48
1,648
Johor Bahru
brass balls ah you guys!
me over 160km/h already sweating my balls.
i'll see if I can meet up with this tony guy again.
or better still, why dont you guys drop by SHC?
singapore honda club.
tons of info there
recently i came across a SpecR mag.. There's a Skyline R33 with TOMEI engine transplant in... It's exhaust system was fitted with a silencer.. Will it restrict the exhaust gas flow??
Some forumers said it wont.. some says yes..
which 1 ar??
can someone explain to me??
i'm dumb la ... wht to do...
