speed cut.
mr.edrick
211
it works gr8 as i mention earlier...it increase d hp up to 18horses..piggyback all works d same..d tuning is to make ur throttle more respond..tune for better air n fuel ratio...n lots more which i also forgot edi. :biggrin:
thanks lord. that's wat i wanted. i dont wana touch my original ecu, as i dont want anything bad to happend and kaboom my engine lol
Z-Ice
323
Mine's with Unichip. So far, response has been good after tuning.
Techno350Z
236
penang
Oh...Many ppl use Unichip at here...I think Unichip should be no problem since u guys using it with no problem...^^...
mr.edrick
211
btw lord, can tell me the brand of your piggyback unichip you using.?
mr.edrick
211
ohh okay thanks. the unichip is use able for any transmission rite.?
huakenny
LB Performance
9,126
240
Kota Kinabalu
why dun use pivot speed meter if just wanna remove the speed cut?
it required to splice only 1 speed signal wire at ecu harness, another will be just power cable(tap to ignition) and another is ground cable (car body/chassis)
NOS_7AGTE
322
3,018
I got used HKS SLD took out from my perious 350z (auto) its still worked fine. anyone interested pm me. thanks
cwf86
244
7
Research properly before using any piggyback as our original ecu is very smart. If you are using a piggyback with same or less bit as our original ecu it might reset to default sooner or later because the original ecu will slowly take control and reverse all the tuning that you have done. Personally still using Unichip and speak from experience. Moreover, you will notice every function and feature in your car to be laggy.
Best if you reflash for minor modifications or get a standalone ecu such as HKS FCon VPro if you planning to major modifications such as supercharge/turbocharge/stroker kit.
I just saw a road bully drived by an Indian driver bearing registration number WRM 3297 Perodua Viva light green color. This car driving so fast and almost bang another car A. Driver A honk this WRM3297 car, guess what happen next?
That Indian driver overtake driver A and slow down causing the jam at LDP Kelana Jaya area. Suddenly Indian driver stop the car right in the middle of LDP, come out and scold driver A. I was behind these 2 cars and know that this Indian driver is...
