speed cut.
mr.edrick
211
it works gr8 as i mention earlier...it increase d hp up to 18horses..piggyback all works d same..d tuning is to make ur throttle more respond..tune for better air n fuel ratio...n lots more which i also forgot edi. :biggrin:
thanks lord. that's wat i wanted. i dont wana touch my original ecu, as i dont want anything bad to happend and kaboom my engine lol
Z-Ice
323
Mine's with Unichip. So far, response has been good after tuning.
Techno350Z
236
penang
Oh...Many ppl use Unichip at here...I think Unichip should be no problem since u guys using it with no problem...^^...
mr.edrick
211
btw lord, can tell me the brand of your piggyback unichip you using.?
mr.edrick
211
ohh okay thanks. the unichip is use able for any transmission rite.?
huakenny
LB Performance
9,126
240
3,163
Kota Kinabalu
why dun use pivot speed meter if just wanna remove the speed cut?
it required to splice only 1 speed signal wire at ecu harness, another will be just power cable(tap to ignition) and another is ground cable (car body/chassis)
NOS_7AGTE
322
I got used HKS SLD took out from my perious 350z (auto) its still worked fine. anyone interested pm me. thanks
cwf86
244
7
Research properly before using any piggyback as our original ecu is very smart. If you are using a piggyback with same or less bit as our original ecu it might reset to default sooner or later because the original ecu will slowly take control and reverse all the tuning that you have done. Personally still using Unichip and speak from experience. Moreover, you will notice every function and feature in your car to be laggy.
Best if you reflash for minor modifications or get a standalone ecu such as HKS FCon VPro if you planning to major modifications such as supercharge/turbocharge/stroker kit.
Proton Holdings, through its subsidiary, Proton Edar, together with total logistics provider, Konsortium Logistik, has just launched its state-of-the-art cetralised logistics hubs in Sijangkang and Tanjung Malim to handle fast delivery of vehicles as well as pre-delivery inspections.
The hubs, known as Center for Logistics, Allocation, Storage and Services (CLASS), was launched by Tun Dr. Mahathir...
