ori perdana v6 vs. perdana TT
virus-v6
146
just throw in a evo3 engine n that will show u the horsie goes up and lots of aftermarkets to install.but the cash flow is awesome ,if u prefer for real real turbo mod for perdana.While if u prefer for less FC maybe go for Eterna tt but V-tec or Mivec is kow kow tuned,i guess u say bye bye.V6 tt is recommended for cruising not for performmance anyway i own a pertdana EVo 3 and cost me around 15k for the transplant.me also seldom use my ride as i'm using my wifes viva hehehehe hope this will help u bro:smokin:
lando88
28
go for TT bro... it's awesome...i drove my fren TT damm nice. 6a12TT is da best...got lot of money, buy 6A13TT. haha just my 2 cent
Melfice
52
Kedah
anyone want 6A12TT-MT Engine include bodypart can contact me at 0175083824 halfcut condition price can be negotiate. call then we talk . . . . . .
jj.v6
332
13
johor baru
im used to drive perdana v6 auto..but now been converted to twin turbo manual..not much different in fuel and maintenance..actually fuel consumption is better than v6 auto.maintanance is the same..make sure u get the proper one.if there is concersion being made,make sure urusan jpj has been settled..power is gud.no problem u can whack evo 3..with stock twin turbo..just get power cut meter (pivot speed meter)
few things to watch..
if u want higher boost..dont go more than 1..and get a gud oil regulator,(sard )and fuel pump(walbro)
if u want more then 1 boost. u got to chage ur engine gasket to metal gasket..
and gud suspension system..
u will be the king in highways..
my best so far is 240km/h(taken from my pivot speed meter)
jj.v6
332
13
johor baru
its depends on size and brand..there r few with 0.4 mm to 1.2 mm.its depends on ur head&blocks condition and compression ratio.a lot of brands from hks to no name..around 1k-3K..
Ahmad K
10
bro..6A12TT standard stock already extrack 215hp but 6A12TT-RS standard stock already 240 hp.
the RS version already come with white meter interface..except dat, all is the same.
p/s: vote for TT of course..if got sum money..cnvert to single turbo (etc. TD05, A/R 70) then u can really feel the power of V6 Turbo...:driver::driver:
Is it expensive to convert to single turbo? Estimated cost? Is this roughly the same for continental cars as well...or?
Rex551
133
22
Krish76,
If your'e looking for a workshop that can handle your engine conversion and upgrades in Penang, I'd suggest "Jaspal Motorsports" laa. Call Glen at 012 6365800 and check them out.
They sure know their stuff and hardware...
Try tengok laa
DanzEterna
15,911
3,371
www.primeperdanaclub.com
ahmad k...converting to single turbo, (AR70 turbine) costs approx rm10k, must as well convert to evo3, summore there is still market value if u wanna trade in your 6a12tt.
TopRpm
295
46
bro..nowadays many TT already convert to single turbo..u can go to piping specialist (Ijal Exhaust, Robert Exhaust etc.) for the single turbo conversion. It is really extract the true power of V6 engine..power band is more higher..but sacrifice a bit the fuel consumption...(u wan power lorr) :driver:
jj.v6
332
13
johor baru
and ur money tooo:biggrin:
TopRpm
295
46
hehehe...
but bro..many of my frens in TT-Evo club aleady did dis kind of mods..300-350hp easily can achieve (plus unichip):driver:
This simple circuit makes it posible to monitor the charging process to a higher level.
Final adjustsments are simple and the only thing needed is a digital voltmeter for the necessary accuracy.
Connect an input voltage of 12.65 volt between the positive and negative poles and adjust the 10K trimmer potentiometer until Led 10 lights up. Lower the voltage and in sequence all other Led's will light up. Check that Led 1...
