Car Radiator
lonelylilpig
832
33
That guy written there got sell racing type 1 wut, or u can get EK type than modify the bracket then its ready use. Just my 2 cents ....
sicilian_defense
22
1,503
maybe its becoz mechs mix coolant with pipe water and not RO...any water other than RO contains minerals... thus the corrosion... It's beter to use RO, unfortunately, I did not do so the lst time I did the coolant Change. So the next ytime when u wanna top up your fluid, GUNALA RO
keisukosan
316
7
i duwan mod the radiotar kaki,wan it be ori so look nice abit...
using RO water is good conditon and toyota LLC is the best choice for me... seems many of high performance using it also :driver:
lonelylilpig
832
33
I'm not sure about RO water. As i know pure distilled water is the best suited water for the whole cooling system.
hawick
346
D'sara / S'ban
Aluminium radiator can filled with coolant but not those bought at hypermarket 1...
Toyota coolant is recommended (info given by radiator seller: omels)
Don't save on coolant but destroy your radiator on future, btw Toyota coolant is only RM24.50/L.
netmatrix
2,255
42
P Jaya:Malaysia
kh_tan.tripod.com
Waaahhh!!! So expensive already? I'm running prestone for RM19.90 per litre from Ace hardware! Last time RM19 only for toyota. Might ponder Perodua one.
Distilled water is the best for radiator. You can use it even without coolant. Some coolant have acid in them to clean the rust. But i have not seen what other special formula they put inside every bottle i saw. The common one is Ethyl Glycol. Its actually an anti freeze (winter) & anti boil (summer) chemical.
The Baja 1000 is one of the most grueling, demanding and torturous rally’s in the world. And Bill Caswell is going to take part in it with his $500 BMW E30 bought off Craigslist and put together in his mom’s garage and partially at the SEMA show before heading to the sand dunes of Mexico.
Caswell’s no stranger to competing in beat up machines and...
