exhaust system
don2324
14
salam bro2 skalian....nak tanye skit pasal exhaust system ni, intro die aku negine asal sohc vtec auto pastu conbert manual gearbox...ok soalan2nye
1. extractor yang bagus 4-2-1 or 4-1?
2. piping size yang sesuai?
3.muffler s-flow or straight flow?
ok...T.Q
Jakk
403
84
Selangor
1. 4-2-1 for top speed and 4-1 for acceleration. its up to u.
2. tunggu sifu sifu lain jawab
3. straight flow suitable for manual.
editted, thanks sifu sifu:redface:
AD_EG
6,328
231
Ipoh
isn't it the other way round?
caleb_5375
1,293
14
okok...4-1 header is good for top end REV...4-2-1 is good for all range of RPM from low till high..
size piping i will prefer 2 inch with mandrel bend lor.
since it is manual d....straight flow is for better performance while s flor give u more silent exhaust sound as ur exhaust noise trap inside the muffle longer then the striaght flow...
don2324
14
if i use the s-flow muffler will there be a negative effect...like lack of power or something....
is there any branded extractor for sohc vtec?...i asked powerzone they don't have it...
caleb_5375
1,293
14
actually we should give our exhaust system as less back pressure as posible....if too small diameter the gas can't come out fast enought..if the diameter is bigger then requirement then the gas will come out slow as increase in diameter..this will make the exhaust gases velocity slow down...the hotter the air the faster it travel...USING a S flow will let u decrease in power coz the exhaust will trap inside the muffler but the advantage is u get silent exhaust then straight...
no matter s flow or straight u plan to use in demand of the noise oso....the most important things is the bending part of the exhaust...u must use mandrel bend as it din get KEMEK on the bending part while slow down the gases....
don2324
14
what do tou mean by mandrel bent?....and why do people say s-flow better for auto tranny, does this mean that all the car using s-flow muffler is underpower
caleb_5375
1,293
14
mandrel bent exhaust is that it's diameter din get smaller at the bending part..if a exhaust pipe of 2inch with mandrel bend u can see no matter how many bending they are the pipe size remain 2inch. normal exhaust shop bending the exhaust at the bending part which will cause the diamter to get smaller....
i been ask by this question of urs like s flow of auto tranny is better then straight and i cna't find a 100% answer for it..but for a manual tranny and street or drag machine ...we need to get as less back pressure as posible..
don2324
14
thanx for the info...but what i want 2 know is why for manual is better straight flow and auto is better s-flow? does it have to do with the setting of the ecu or the RPM, or......?
Wanggot
3,906
62
Jay Bee
My end muffler using 2.3 inch ok or not? Fren told me to change 2.2 inch
caleb_5375
1,293
14
dun know bout that like straight for manual then s flow for auto...really wan to know then we got many setup and take it to dyno...see the HP figure jump or the torque figure jump...
---------- Post added at 11:28 PM ---------- Previous post was at 11:24 PM ----------
if for b16 the whole piping 2.3 inch with the muffler inlet 2.3 oso ok ah...thats the best d ...with an aftermarket exhaust manifold and type R downpipe more chun....but u need to mod some porting or type R cam for best coupe with the type R downpipe...but 2.3 inch to 2,2 inch wont let u feel much honestly...
don2324
14
if i want 2 use a 2'' piping but the muffler inlet is 2.3'' straight flow, is it ok or not? and the muffler brand is HKS super dragger
Hi guys,
I need help from you guys. I'm trying to find 2nd hand woofer or sub woofer and CD + MP3 player. Can you guys help me on that?
Thanks,
Regards,
ajis2040
