For sale is my EK 2door with the following specs:
B18CR 1.8L Integra Type R (DC2) Block
Original EK9 Head with Type R Tapered Intake Valves
After-market Loss Motion Assembly LMA (VTEC rocker retainer during low-cam operation)
Skunk2 Pro3+ Cams
Skunk2 Pro Series Adjustable cam gears dialed to spec by HVRacing
Skunk2 Pro series Valve Springs and
Skunk2 Pro Series Titanium Retainers
Compression Ratio 12.6:1 to support the high cams
Port-matched and polished head done at HVRacing
HONDATA S300 ECU Tuned by TungChun
- the best ecu for HONDA. can set auto aircond shut-off at pre-set RPM or when WOT, launch control, full-throttle shift, check engine light as shift light, etc..
Complete EK9 99 Wiring from engine, headlight to tail light
B18CR Intake Manifold and Throttle Body
HONDATA Heatshield Intake Manifold Gasket
Top-Fuel Intake
HKS Super Power Flow Pod Filter
Integra Type R S80 N3E Gearbox with Helical LSD and 4.785 Final Drive
EK9 Clutch set
TODA lightened 4kg Flywheel
Lightened Aluminium Crankshaft Pulley
Full Aluminium Radiator
SARD Japan Fuel Regulator
EK9 Recaro Seats
EK9 Rear seat
EK9 Complete Front Conversion with original RS grill emblem and Raybrig fog lights
EK9 Complete Rear Conversion
EK9 Red Carpet
EK9 Floor Mat
EK9 99 Dashboard
EK9 99 Center Console
EK9 meter
EK9 Red Door Trim and Black interior skin
EK9 99 Pillar cover
EK9 5lug Diskbrake
EK9 wheels with POTENZA RE01R tires (65%)
EK9 front and rear anti-roll bar
EK9 spoiler and dark rear glass
Apexi N1 full height and damper adjustable suspension system
Apexi GT exhaust full set from cat converter to end
Silver's Engine Damper
And it goes together with JVC MP3 headunit, 2 x Sony 6" 3-way speakers (front), 2 x Sony 6" x 9" 3-way speakers (rear), Blaupunkt power amp, and Mohawk 10" sub.
Price: RM65,000-00 Negotiable
PM to deal
No low-ballers and no silly questions please
Cash buyer preferred but if you can find your own financing, that will be good
Skunk2 Pro3+ Cams
Top-Fuel Intake
EK9 Clutch set
EK9 Recaro Seats
EK9 Rear seat
EK9 Red Carpet
EK9 Floor Mat
EK9 99 Dashboard
EK9 meter
EK9 99 Pillar cover
EK9 5lug Diskbrake
PM to deal
