FD aircond problem
muikit88
100
2
Malaysia
my FD cant on air cond at 3/4...
but 100% normal at 1 /2 ~
my humtown mechanic said is the air cond switch~
but bro-woaychee tell me tat is relay~(thanks bro)
but, my humtown mechanic said them duno wat is relay wor~
sumore there not dare to touch~
anybody can tell me...how im going to fix tis problem n where n how much ?
my location is in prk~
woaychee
212
44
mun kit, he donknow air cond relay?
last time my problem is, 3rd and 4th no cold air, only hot air out blow out, so sent the car to air cond shop, he said my car need extra relay to support 3rd and 4th, so after 30mins of work, he manage to make it work.
hope is the same problem you face.
cwcham
78
7
3,008
i heard some a/c shop in sg long could fix your problem. I used to have that same issue last time but i didnt have time to bring it there so i pass it to ahchoy. i think he brought it to the a/c shop in sg long.
anyone have any idea where it it and whats the shop called?
Bump: i heard some a/c shop in sg long could fix your problem. I used to have that same issue last time but i didnt have time to bring it there so i pass it to ahchoy. i think he brought it to the a/c shop in sg long.
radicaliez
123
18
3,018
kuala lumpur
www.radical.com.my
emm..ahchoy also sent to other ppl ?
thought he can fixed it himself...
sometime i wanna sent to normal a/c shop..eventually they will do the "try n error" trick..end up we have to spent thing that should not to be change.
any recommended a/c shop which fluent with rx-7?
woaychee
212
44
if you just wish to fill up the gas, you can do in any shops. Prefer you go to those shops that you familiar with. RX-7 air cond is same normal car air cond. AGAIN, they must know what they are doing..
i met a problem , do wiring tidyly with using the Voltage stabilzer or Immobilize or some like Hongkong Voltage Stabilizer with Bettery Charge or supply is better ? let me know ..the wiring will cause voltage go more stabile but do it make car performane to go distributor then to sparkplug have better effect , have feeling for turbo ? let mek now ..if yes i will go for it
