DIY engine damper
erictan30
167
have anyone try to DIY engine damper?
i've seen some one DIY using Hood damper so it's cheaper
SkYwAlKeR
Over 10,000 RPM!
10,139
300
5,183
ePoh ~ malacca
engine damper is tougher and shorter compare to hood damper lo...
but if u mount a few hood damper, it is possible geh...
but u must do custom bracket to hold it in place lor....
erictan30
167
i have a friend mount 1 of the camry's hood damper the damper is damn hard le.aerospeed wan is much softer.and 2 hood damper will only cost 1/3 of the real engine damper..engine damper is also available for certain models only.also need to mod
SkYwAlKeR
Over 10,000 RPM!
10,139
300
5,183
ePoh ~ malacca
so in conclusion, it is possible... jz that u need to find out which part of ur engine vibrates most when revving and mount the damper there... make sure the bracket is done properly and the dampers is stiff enough (but not too stiff la)...
obey_1986
15
i just done my engine damper with only $$ 0 spent.....i get the absorber damper from those absorber use in furniture one from my dad,n 2 pieces of steel piece.....den mount it on the engine mounting on the timing belt side.....superb result....
SkYwAlKeR
Over 10,000 RPM!
10,139
300
5,183
ePoh ~ malacca
any pictures to share??
obey_1986
15
this is the diy engine damper i have done....do gv me some comment...thanks
Invinsible
49
2
1,508
what the function of dis damper?to assist ori engine mounting?..
anyone can explain it?:hmmmm:
Actually it's use to hold the engine so it won't vibrate too much...The engine vibration force will absorb seperately by the mountings and the damper..
Correct me if i'm wrong...:biggrin:
The Marketplace Top Posts
how to tuned...because my rpm to low...about below 500..... :huh: ....help me... :(
