AE101 rear suspension problem...
Naim
102
To all toyotarian sifoo...need sharing and your experience..
just want to sharing idea...how to increase high at rear suspension..
now use new absorber and fix stock coil spring...carry 2 passenger my car look "lowed"
other guys says change coil spring ST171 model..true or not..or use ST171 absorber and coil spring complete..
nnik
3,676
Lembah Klang
sv4 n sm4 honda rear spring....should help
t-la
1,080
20
5,138
secret place
look for harder rear sus. that might settle the problem
scottwrx
870
24
hehe.. i was just about to order the silicon spring wrap, but a set of four lah.. only using 2, u wanna share share ar? i think got a post selling for 160-180..
if not use adjustable lah...
azahari.aziz
182
i got this problem too
but already settle it...
my fren do this to me..
but i dont know what he do...
coz i sent my car and go home..
used standard abs and spring...
my car can put 18" rim with 225/40 tyre
now already use 17" with 225/45 tyre..
no touching with wheel arc Fr n Rr..
you can carry 1person and 3person at the back
with fully loaded at the boot..
high its up to u...
if you want just pm me...
i can settle it for you
include installation..
muzhaffar
251
41
bro?
what is silicon spring wrap?
is it the red one that placed between spring?
look like rubber one?
i know someone who sell it at rm35 for 2 pieces
so, for the whole car, only rm70
dennisdreams
333
21
yup, ST171's spring did do the miracle. you would be able to carry more load and your absorber will last longer. the so call silicon spring wrap will help improve the situation a bit but it will wear out in shorter time period compare to changing spring would last longer. The purchase price of the spring wrap should be less than 50/pcs, or you were buying overprice merchandise.
p/s SV4's rear spring is not compatible with SEG/AE101,111 in both size,diameter and length.
2 Old 2 Rusty
1,987
66
1,648
Yup, you're right, Dennis. The SM4 Accord springs are not compatible with the AE101 shox.
I'm not sure about the SEG body but my Corona used to have the same problem too but the only difference is; the ST171's springs didn't do the trick for me, although the ST171's springs do look taller than the stock Corona's. The rear tyres (only using 195/50x15) still scrapping the arches when fully loaded.
:listen: My cure came from the ST185 Celica's rear springs. It's plug & play for the AE101 shox. Still using it on my wife's car now. It's a progressive spring & the spring rate's just nice.:driver::love:
The only setback would be bcoz it's quite rare. I had to buy the whole shox just for the springs. The shox won't fit the AE series although the holes for the knuckles are ngam but the spring's "cup"/holder will foul the tyre.:banghead:
EDRA
789
4
i am also need some advise from u all. my rear suspension too soft. when carry 2 pax its touch the mudguard. i am using 215/45/17.
is there any harder coil spring suitable for ae101?
scottwrx
870
24
i m not sure about the price of the item lah.. coz what i know is there are 2 types of wrap, one is rubber another is silicon... rubber one selling for 35 per piece n silicon one i think around 160-180 per set of 4 pieces..
anyway since you already provide a long term a solution, u got st171 spring ar?? sell me cheap cheap lah.... hehe... i go to ur place loh... jln bukit panchor right ?
2 Old 2 Rusty
1,987
66
1,648
I thought we just mentioned that the ST171 Corona & the ST185 Celica springs, right ?
:listen: Anyway, I think your wheel size is too big. I'm only using 205/40x17; can't even use 215 coz of tyre scrapping fender issue... & that I'm using adjustable shox.
EDRA
789
4
thats why i am asking for harder coil spring. rear i use 215/45 for good cornering time when single driving. 40 series too thin can cause punctured/bengkok rim if hit big rock or jatuh lubang. langgar batu kecik pun boleh rasa.
2 Old 2 Rusty
1,987
66
1,648
Then I suggest you go for adjustables; even much better for cornering ! I don't know lar, it's quite difficult to have a perfect package, bro. It's more of a compromise situation coz if you talk about cornering, then 40 series is even better than 45 series due to less tyre sidewall flex.
Actually when it comes to cornering, you can always use a better tyre, rather than talk about lesser issues such as sidewall flex. I believe, a good 195/50x15 tyre will take the corners just as fast; if not faster if compared to using a lower grade 225/45x17 tyre.
If you talk about the langgar lubang & rim bengkok stuff, then better use 60 series lor... or 15" rims, don't you think so ? But it wouln't look good, am I right ? :laugh:
That's why I said it's difficult to get a perfect package, bro.
:listen:Just my opinion, that's all.
Hi,greetings,I have some questions about coilovers,I was about to change my standard shock to TEIN HA coilovers,Then i test ride on my friend cars with TEIN also,driving performance are smooth while taking curved but,when it come to coarse road,the ride become very harsh,I want to balance beetween comfort ride and lowered car,Is it advisable to use coilover on malaysian road,I live in kl.My ride have 40 profile tyre.
