Need Advise for Tial Wastegate
evo5755
332
3,018
I am looking forward to get a Tial 38mm wastegate, but it came with "bar" standard. 0.5 bar and 1bar...now how do i determine which to get?
oly
823
2
3,018
Lumut
im using 0.5 bar one...first n second gear is nice...almost no spin...on bridgestone re001 and td05h 20g...but 3rd gear is lemau a bit...dunno why...maybe my car...and im selling my wastegate with banana for rm1.4k...plug n play for evo n vr4 with standard td turbine...
proPIPING
1,077
5
using stndard actuator how many 'bar' did you boost your car?it will roughly show the spring pressure that you needed....
jinkl
4,624
376
3,183
wht spring rate to buy, its simple
buy wht minimum boost u would like to run
0.6bar spring can be turned to run at 1bar with boost controller
but there is no way u can make a 1bar spring to open up at 0.6bar
evo5755
332
3,018
Jin,
As always your explanation is good. This makes sense with irreversible boost changes..hehe.i will not be running as low as 0.5 bar, but will run from 0.8bar for normal driving or as high as 1.5bar of boost pressure for "sport" driving. So, can 0.5bar spring withstand 1.5bar of boost shall i tuned it with my Electronic boost Controller?
evo5755
332
3,018
if you want to sell your wastegate cheap cheap can la...hahaha..anyway i think wastegate has nothing to do with your 1st 2nd 3rd gear response. There are so many more factors that contribute to this. Wastegate is a gate that dumps all the waste gas into atmosphere...
evo5755
332
3,018
do consider a Turbosmart 38mm..smaller and lighter and flows better...single piece CNC valve for strength and precision.
http://www.autojunctions.com/index.php?option=com_fireboard&Itemid=59&func=view&id=321&catid=57
cheers~
Thanks SDF. Turbosmart will be in my consideration list too, but i wonder why the "pricing" is tad bit higher compare to Tial? Since this two is the most wanted wastegate in the market, perhaps price strategy should be nearer? Anyway just my cents ok..
perhaps in future you can bring in something called "Synapse" to Malaysia? :)
SDF
missing her so much
Nov 19, 2003
2,354
275
5,183
KL, Malaysia
prices are retail.. i'm sure our Dealer will make you a deal when you visit them :idea:
as for Synapse..well..good stuffs..will the average consumer pay ? and with 2 outstanding brands dominating the market...well... you guys know the equation. :hmmmm:
SDF
missing her so much
Nov 19, 2003
2,354
275
5,183
KL, Malaysia
better to use a boost controller to manage the boost level settings.
grab a 0.5 bar wastegate and it'll hold fine even if u run it to 1.5bar.
speed2horizon
2,798
334
1,683
Actually Tial is nothing consider expensive comparing to thailand or chicken brand, of course tial is expensive... Compare with HKS, Tial has got no where to stand....
Tial is more of a affordable wastegate. that's why it's so popular....
evo5755
332
3,018
Ok then. I will pay your dealer for a visit....:)
Elo bro out there......
Spec: wira 1300cc, 4G13 engine.
My car crank pulley sound "Ring ... Ring...". During engine start, there is no sound but some time later the sound appear. Especially, on air-cond & light (at night). Why? Crank pulley "Kong liao" kah!!
Went to workshop than changed new crank pulley. First okie,.... but now slowly some time still can hear little bit "Ring... Ring..." sound too. How huh..... is it the car timing too low than air-cond & light on not enough power...
