Kaitospeed : Brembo Max Waja/Perdana New Stock!
kangyoon20
Over 10,000 RPM!
10,439
18
Malaysia
www.geocities.com
Genuine BREMBO MAX
BRAKE DISC (Waja/Perdana)
If you are looking for affordable replacement brake disc, but would prefer something better than your standard disc, we would recommend Brembo Max.
Brembo MAX provides improved braking performance under all pressure and speed conditions tested in the laboratory and on the road. It also ensures greater safety in wet road conditions.
The new high performance brake disc guarantees shorter braking distance and provides improved braking performance under all conditions.
Maximum Monitoring of Wear
One of the Brembo MAX grooves has been specially designed to permit a direct, rapid check on brake disc wear. When this groove is no longer visible, the recommended minimum thickness level has been reached; an indication that users should replace the worn disc. Even so, the braking system will still continue to function thanks to the remaining grooves. A similar wear indicator groove, positioned exactly opposite on the internal disc braking surface, ensures that the disc is perfectly balanced.
- Latest stock shipment from Brembo Italy (April 2008)
- Brand New in Box
- Plug & Play on Waja/Perdana without ANY Modification
Item Include :
- 1 Pair (2units) Brembo Max Brake Disc for Front Application
Specification :
- Diameter : 256mm
- Thickness : 24mm
- PCD : 114.3 x 4
- Centre Hub Hole Width : 69mm
RM480/pair
Beware of Imitation in the Market
Reference for Genuine Brembo:
Wraping
Come with latest catalogue
Pin Number
brembo MAX marking on the side of the disc
FREE brembo stickers from Kaitospeed only
T&C
- SKYNET Courier Service - RM20 Flat Charge to Whole Peninsular
- PM for COD details
- Installation is NOT included
- Promotion Nett Price
- Goods Sold are not returnable. Please make sure the correct model is ordered
PM or Contact 016-7442406
Kaitospeed Performance Autoparts
CLICK HERE to check out more promotion items!
nikewai
293
how much for the brembo front pair for 1.6 wira?? PCD 100 X 4 holes?
L200s
37
3,008
Bro..im looking a bit larger disc brake for my perdana compare to the std one. Is this suit my interest?
kangyoon20
Over 10,000 RPM!
10,439
18
Malaysia
www.geocities.com
helo bro
as mentioned in my sale post,
this brembo MAX is direct plug and play for perdana which has the exact dimension wif OEM disc.
if u plan to change to a bit larger disc then ur caliper may not fit it
sorry guys and dudes here, i know this topic has been discussed a million of times but i have something to know.
i went to the shop and ask the boss there said:
LOWERING SPRING and SPORT SPRING is different
Lowering Spring the coils it lesser than stock (like potong spring product)
Sport Spring the coils is like stock or more than lowering spring 1 but it gives lowering effect also.
So is it correct?
and which spring is reasonable to buy in Market for LMST?
I asked the shop...
