850T : the making for daily
pharin
152
between 850 internal n 660t
up : 660t crankshaft that help producing hi-rev n good response
below : 850 crankshaft that produce hi-torque
at right : 850 rod longer than 660t rod
L2 carb turbo,same size 68mm L2 injection turbo pistons..option for those who want pump hi-boost
my previous L2 carb pistons in my ED...calar bcoz hi-rev until 9000rpm at 1.9 bar
**don't do it again hehehehe :banghead:
pharin
152
after my engine gotta problems, due to hi-rev n hi-boost, my mechanic propose me to fit oil jet that only available at turbocharged block...of course 660t..into my 850 block.
that is secure step to pump engine oil downwards piston side..that helps preventing brute frictions at hi-rev (that's why high block kenot hi-rev all the way compare 660t can rev 8000~9000rpm hehehehe)
inside ED850 block : oil jet unavailable
inside 660t blok (yellow circle) : oil jet available
**just my rnd, lain pomen..lain cara loh
pharin
152
underneat both blocks..at right is 850 block
near internal parts where crankshaft bearing placed....
no hole available for oil jet at 850 block
another hole for oil jet for engine oil pumping from oil sump
i bought engine kosong L2 carb at rm400 just for oil jet n pistons 'kawah' L2 carb to my 2nd phase rnd n replace my previous L2 carb pistons yang calar...huhuhuhu
luckily my block never scratch... pheww..just slot back another L2 carb pistons into my bored 68mm ed block
:mad:
pharin
152
my car tsadai at 3 weeks
last 2 days progress
**** after dis i take my car, da siap hehehehe
my previous setup..and after dis, sama loh...nothing changes till now
peace :wavey:
pharin
152
Chassis : Perodua Kancil EZ850 year 1998
Engine specs ;
 Engine based L5 single cam
 Blok 850, crankshaft 850, conrod 850
 Piston L2 carburetor
 ACL performance engine bearing (Australia)
 RK heavy duty piston rings
 MetaL gasket kelisa
 Port n polished L2 head
 Mild camshaft by NSDrag
 TD04L GTO balanced by Tong Turbo
 SR20 intecooler+piping ic 1.7â€
 SARD R2D2 blow off valve
 SARD fuel regulator (small)
 RB26 fuel pump
 RB20Dett injectors 440ccx3 (ntah betul ke ni..)
 Custom oil catch tank by tangki wiper
 Fully silicone hoses by Samco and HKS
 AVS silicone radiator hose
 Downpipe 2â€+exht. Piping 2â€+RIMUS 2 ½ outlet muffler box
 Custom dumppipe
 Volt stabilizer+grounding wire
 Fully Aerospeed thermal wraps
Lube
 HKS semi-synth 10w-40
 Castrol protector series gearbox oil
Transmissions
 850 gearbox
 Trinity 3 pucks+double pressure
Tuning stuff
 S-AFC 1 blue screen
 RSM blue screen
 SMC manual boost controller
 Blitz 3†boost meter
 Blitz turbo timer
 Auto Meter AFR meter
Stiff Stuff
 APM performax absorbers
 APM Sportec coils
 Ultra Racing 4 points rear bar
 Ultra Racing room bar
 Hot Bits front stabilizer bar
Roller n Stopper
 BRW (Blitz Racing Wheels) welded 14†x 6 ( now pair of wedsports 14†– front)
 Toyo Trampio 165/55/14 botak daa
 L5 rear disc brakes
 L2 front disc brakes
 Mikuni brake pads
 Alloy wheel nuts
Interior
 Isotta leather 13†steering wheel
 Sparco junior fully bucket+Sabelt 4 points harness
 Seatbelt Mira
 L2 avanzato seats
 L2 gear column
 Felix the Mira carpets
 Carpet lantai hitam Mira
 Bumbung ombak 2 doors (cukup syarat) + 850 pillar cover
 Sunshade mira
 Pioneer DEH-1450 50w x 4 cd player
 Mira trxx by Pioneer tiang gol speaker
 Cap ayam/ jln pasar 150w door speaker
 Driving school mirror (sisik)
 L2 dashboard with L2s meter
 L2 door panels+4 power windows
Exterior
 Fully L2s JDM bodykit
 Antenna tengah kedai abang’s (itam)
 Fully cromax glasses
 Mira cromax headlamps
 Myvi’s crystal white paint
Performance
 151.7whp at 1.8 bar
 Autobahn highway busuk MRR2 195kmh at 1.0 bar
Achievement
 SDB 2007 round 2..kaput within 16sec
 Compact Dyno Challenge round 1 : 2nd place at 120.9whp
 Compact Dyno Challenge round 2 : 1st place at 151.7whp
 Compact Dyno Challenge round 3 at 134whp
 SDB 2008 round 1 : 15.3sec = best 8 in cat.E
 SDB 2008 round 2 : 14.26sec = top 10 best timing
 Charity Drag Kpg Gajah : 2nd at 850~1000T cat.
Bengkel : ANN Autogarage and MIG Autogarage
:wavey:
ART///SPEED
287
oil jet can be done lah at n/a block...so easy just drill it and fit it
rotaryfans
46
Nice car with pics and explanations !
for daily use some more ..
how is the fc of ur 850t ?
good luck for future mods
pharin
152
artspeed : thanks 4 explanations, b4 that my fren did it at EJ blok by himself. after 3 months his block crack at water jacket... never do it 'pandai2' so i send it to engineering shop :wavey:
ronniehor : thanks :wavey: and on the road
rotaryfans : my fc after petrol hike (fuk lah 'restructured') rm30 for 110km.average driven at 70~110kmh
rotaryfans
46
rm30 for 110km
it is quite horror !!
i m planning to transplant l2 ...
now have 2 reconsider due to petrol price ...
btw , how much is the half cut now ?
pharin
152
yup, fc rite now quite horror, even i ride to work everyday with my rxz olso rm3 KL-USJ huhu
b4 petrol hike, fc for stock L2 just 65km for rm10..
hafcut rite now around rm2.6k~rm3k..... cisss
ART///SPEED
287
yeah must be done by engineering shop lah
boy dtn
175
wah this car very nice and power..superb job bro:biggrin:my car only 1 bar:joyman:
pharin
152
wahhh boy datin don't shy2 daaa
iz's motors 1 bar but tapawed me at sdb round 2 hehehehe..
what's new from PG last saturday? hear dat ur wastegates patah :O
strangex2
238
Price for halfcut L2 (no bodyparts) increased. How about the price for L5 turbo? Also increased ah? Last month went and ask, all also around RM2,700 for L2 no bodyparts.
Similar threads   Forum
Revanus Introduction and Newbies
DR78 General Talk
News and Features
Y General Talk
A Introduction and Newbies
Wheel And Tyre
Car Modification
News and Features
J General Talk
News and Features
Wheel And Tyre
Wheel And Tyre
Proton
Car Talk
Euro
  Similar Threads
DR78 General Talk
News and Features
Y General Talk
Wheel And Tyre
Car Modification
News and Features
J General Talk
News and Features
Wheel And Tyre
Wheel And Tyre
Proton
Car Talk
Euro
Guys,
Stolen car belongs to a very good friend of mine. Here are the details:
Model: Proton Wira Sedan
Registration Number: TS 7112
Colour: Pearl White
Date Stolen: 28th June 2008 (Saturday)
Time Stolen: Around 6.00pm
Wheel Type: Enkei RS5 (5 spokes)
Wheel Colour: Hyper Black
Engine Type: 4G93 Turbo GSR with MIVEC 'Blacktop' head
Engine Number: 4G93-BK5611
Chassis...
