engine check light's code
jlck
75
4
1,508
Hi everyone here, anyone can tell me where can i fine the Honda civic engine check light's code? (bling 1 time mean ???, bling 2 times mean ??? and else...) thanks for reply...
hattech-v
Over 10,000 RPM!
12,756
12
Seri Kembangan
www.avantech.com.my
1 O2A - Oxygen sensor #1
2 O2B - Oxygen sensor #2
3 MAP - manifold absolute pressure sensor
4 CKP - crank position sensor
5 MAP - manifold absolute pressure sensor
6 ECT - water temperature sensor
7 TPS - throttle position sensor
8 TDC - top dead centre sensor
9 CYP - cylinder sensor
10 IAT - intake air temperature sensor
12 EGR - exhaust gas recirculation lift valve
13 BARO - atmospheric pressure sensor
14 IAC (EACV) - idle air control valve
15 Ignition output signal
16 Fuel injectors
17 VSS - speed sensor
19 Automatic transmission lockup control valve
20 Electrical load detector
21 VTEC spool solenoid valve
22 VTEC pressure valve
23 Knock sensor
30 Automatic transmission A signal
31 Automatic transmission B signal
36 traction control found on JDM ecu's
41 Primary oxygen sensor heater
43 Fuel supply system
45 Fuel system too rich or lean
48 LAF - lean air fuel sensor
54 CKF - crank fluctuation sensor
58 TDC sensor #2
61 Primary oxygen sensor
63 Secondary oxygen sensor circuit
65 Secondary oxygen sensor heater wire (black wires)
67 Cat Converter
71 random misfire cylinder 1
72 random misfire cylinder 2
73 random misfire cylinder 3
74 random misfire cylinder 4
80 EGR Valve/Line
86 ECT sensor - Cooling System
91 Fuel Tank pressure sensor
92 EVAP Solenoid/Valve/Vacuum Lines
jlck
75
4
1,508
thanks a lot...
shiroitenshi
3,676
170
long blink = 10, short blink = 1.. so start counting!
BTW, hattech.. that looks like OBD2 check light codes la... is it?
OBD 1 different, I think.
J101
1,304
malaysia
which model of honda civic and which ecu? the guys would probably help you better with better infos.
cheers
On 20th April 2010, around 10.45pm I parked my car at Jalan SS15/8A Subang Jaya, along the roadside parking lot, near to Pizza Hut. I was on my way going to get some supper at Asia Cafe, and I don't mind walking a little further as it is difficult to find parking there. In my return to my car my front passenger side window got shattered and all my 3 handphones are stolen taken from my dashboard compartment. The handphones weren't visible from the outside, because they were in the...
