BOT (Bolt On Turbo)
wiramax
797
2
Hi need help to BOT my 4g92p, 1.6 sohc engine. Any advice? anyone know wat is my engine compression ratio? Hope u guys can help.Tq
xinghonh
1,415
7
one more ques b4 i start my project...
isit necessary u chg the throttle body and ecu to gsr's ?
detomatoB8
72
1,508
If u are using 1.3 injection mmc ecu, i know one mechanic that can do itfor u.Using starlet turbine.It will cost u rm1.9k include installation.
with the rm1900 spending. what the maximum BOOST it may safe
ie : only play with low boost at 0.6 bar or ur engine KAput :wavey:
just to have a bit research on the best way spending rm1900
iswara204
545
13
BOT sifu's.. must my clutch plate given a high priority to be changed to semi-racing once i BOT? or can i do it the next stage?
feedbacks much app...thanks
GeneJin
435
All sifu here, have any1 any idea where i can find customed manifold for my waja? Do we need the down pipe? I'm looking for low boost, maybe max 0.4 or 0.7. Since mine is an Auto so wont be boostin so high. transmission cannot take it. Is it necesarry for my manifold to have the downpipe outlet too?
scionsigg
144
i think is beta for u to change to semi racing clutch...coz last time after i bot i din chage da clutch...i face a huge clutch slip when ever i change my gear..
GTpuI
512
16
If dont have budget for semi racing clutch,use the daikin exedy Japan heavy duty cluth.
zamiex
443
11
yup.. heavy duty clucth set good edi.. not so expensive also, can last longer depending on how u drive lor.. if hari-hari tekan takbley la..
GTpuI
512
16
I bought that heavy duty exedy clutch set with plate and nsk japan bearing only rm350.
Gtiiiii_01
280
4
hi guys need advice...
my rpm is not working. stock meter just remain 'dead' all the time. got autogauge RPM meter also didnt work. i've tried with apexi rpm meter gave me the same results.already checked the distributor,harness n wiring no problem. one more thing dont know wat gearbox should i use coz evo 2 gearbox that i'm using now not really realliable...
below is my car spec:
4g93p block,mivec head, je piston,eagle conrod,eagle conrod, je blockguard, racing cams,oversize throttle body, custom intake manifold, 700cc sard injector,garrett T04E turbo,hks type 2 bov,tial wastegate 40mm, os giken twin plate, blitz intercooler, banana extractor, 3'' piping, fullset racing bearing, AVCR boost controller, microtech LT10
currently 489.3 [email protected] bar
Thanx 4 any replies...CHEERS!!!
GTpuI
512
16
Wow...Damn fast car...What car u use?
Gtiiiii_01
280
4
proton satria Gti. used 2 be n/a with almost major modification but now wanna try with turbo...
Dearest brothers of ZTH,
I am currently setting up a mechanic workshop at Jelutong/Batu Lanchang whereby car servicing, car repairs etc were offered. Pls feel free to drop by n give me some support to build my business. My workshop is situated at:-
1. if u r coming from Lam Wah Ee Hospital
- after the 1st traffic lights at the Mewah Court junction, u will c a petshop, Wonderland Petshop, on ur left. Our workshop is directly opposite the petshop. There is a gate there whereby...
