how do you open the headlight cover?
ABV9750
322
headlight cleaning
thanks for reply.
actually i want to clean the INNER parts inside the headlamp NOT outside glass.
i'd try using alcohol but can't get rid of it..
i plan to open uip the headlap as suggest by forumer and clean it up but i dun hav an idea to make it nicer back.
i'm not sure by normal cleaning would be a better way or:-
need to use a special chemical?? or
repaint to chrome??
any idea or shop that can rework this.??
thanks in advance.
alvin2002_my
96
i had done mine by using hot boiling water to open the headlamp.
i used window cleaner to clean up the cover and use aluminium foil stick on the chrome part.
ABV9750
322
thanks bro.
seems like its work using the boiling water to open up the headlamp. Ok i'll try.
my headlamp has the bulb protector and its already dull.i plan to remove it.
is it ok? does the bulb too hot that might damage the inner chrome parts?
good idea of the aluminium folder
thanks a lot.
ajeman
put in oven can maaa...me trying myself vit headlamp wira..
that headlamp palstik one,,so easy mei
hope u will good tyring
Maxx
2,072
42
5,148
PD-Putrajaya-KL
www.zerotohundred.com
thanks bro.
thanks a lot.
what car/headlamp?
if using H4 better not remove the bulb protector.
maybe u can just polish it and put it back.
im not sure if its for shield or something.
alvin2002_my
96
thanks bro.
thanks a lot.
at 1st i use window cleaner to clean the chrome part, and i get shocked when i saw that the chrome part drop.. so i have to use aluminium folder lo..hehe..
im using 100/90W bulb, so far no problem with it. :_:
alvin2002_my
96
:regular_smile:
what car/headlamp?
my right headlamp(imitation) is without with bulb protector 1..
so far using it with no problem .:regular_smile:
Maxx
2,072
42
5,148
PD-Putrajaya-KL
if no problem without it than ok la.
btw, do not touch/wipe the chrome parts. it easily drop/"tanggal".
ABV9750
322
headlamp
my ride, elantra 96 has small headlamp like honda EG (facelift also looks the same).the headlamp is glass but the inner is poor plastic.you know la korean car weakers point is the plastic parts.
the headlight is very poor even at hi beam.i've change to 100W but then realise, the temperature becoming worst and now use 60W only. Better!!
actually i prefer to send it for rework to any worksyop that experience. you know, the expetise might do it well.i'd ask a few places but they suggest to replace new headlamp...:(
anyway..thanks to all..i plan to do it myself and update it in here...cheers!
legend7
270
ive done this before :D... all i do is put a small nail between the black cover & glass then by using a knife cut the glue bit by bit :). u must have a very high patient as u cant force it to open. btw, the glue is silicon glue dont think it will melt easyly.
Maxx
2,072
42
5,148
PD-Putrajaya-KL
actually the silicon glue melts quite easily. u can just immerse the lamp in hot water. n slowly do like u did. will be easier.
yuzies
139
Bro, question..
If i wanna spray flat black color on the crome area of my head light like existing headlight sale in market anyone can give an idea on these?
1) How about the reflection of light come out from the head light? Is it less brigthess or no reflection at all?
2) Can lasting the paint black color in the headlight, cause hot temperature come out from bulb?
Anyone has tried this before please advise...TQ
It's an early morning and you're in dire need of coffee. No problem. Here's three-time ALMS GT2 Driver's Champion and Le Mans winner, Patrick Long, heading out for a speedy, exhilarating coffee run for work-mate Hurley Haywood. Apparently, it's a daily morning routine for Patrick and we can see why Porsche allows him to get coffee in a 911 GT3 RS 4.0!
<!--more-->Featuring a...
