Toyata gt86 vs Subaru brz.which is the best?
Which one is the best between toyota gt86 and subaru Brz.
Actually - I read somewhere the main differences between the two is the suspension choices and how the cars are tuned and setup. Same car on paper but the suspension is different and engine tuning is different apparently. Let me try to find the article -
Ok I think I found it but pretty much all article will tell you there's some slight differences with the 86 needs the TRD kit to be on par with the Subaru but at the same time the Subaru also has the performance pack option.
Aiya it's the same car if you're comparing base models. Just buy whichever brand makes you feel all tingly inside.
Reactions: minibeany
lsm1991
1,469
185
dats right.... setup differently... iirc the subi was a 'stiffer' setup...
but end of the day, everyone above is right, whichever you like, thats the best....
minibeany
598
102
543
Incidentally - you'll be damn hard pressed to find a completely stock BRZ/GT86 in the second hand market. So it's no longer a fair comparison.
no meh.... saw quite a lot recond still stock. my friend just got one 86 but in Subaru blue :Stupid:
ixeo
4,788
3,080
KL, Malaysia
In Malaysia Toyota because chinaman don’t know what is Subaru. So when you meet girlfriend’s father and he ask what car you drive, you say Toyota he will give you thumbs up and let you marry his daughter.
ixeo
4,788
3,080
KL, Malaysia
your left testicle better or yr right testicle better?
My left one better, it hangs lower, and we all know lower is better, lower centre of gravity with better handling.
Dear Focal Point,
Good day to you!
I had just recently overhaul my 15 years car's engine (top overhaul and change piston ring) after travelling for 530,000km in my proton wira. The engine cylinder still in good shape since i have been using tufoil for many years. Thanks to tufoil to surprise my forman on such a little wear on my engine block and bearings after such millage. I change piston ring and valve seal just to reduce the engine oil consumption problem, before it was 500ml every...
