KHNG940413
668
56
johor bahru
Thermostat housing not hose. That silver thing is the thermostat housing. Held down by two 10mm bolts. Doesn't look like yours has a gasket though. Should be ok to dismantle and open up. Check that your thermostat is working. Easiest way to see if it opens and closes is to clean it up, and dunk it in boiling water.
Ok,noted thx. Last time I flush the radiator while the car is idling forgot to mention. After flushing I will rev and let the water come out.
KHNG940413
668
56
johor bahru
Wira update.
Before I flush my coolant I felt something went wrong to my car. The temperature is quite high and also when the temperature is high my aircond start blow warm air. After checking is one of my fan motor & blade rosak. A RM150 job.
After changing it the car now run good and cold.
And I still haven't flush my radiator. Hahahahahaha
KHNG940413
668
56
johor bahru
Wira update.
Yes,I bought a Mivec hood. I think is real one since is a metal one not fiber and is RM80.....juz need to cement it and spray or wrap it and is like a new thing.
And also the guy who sold me the hood very nice gv me a sample for the nut needed to fit to my crossmember. After fitting and yes. No shaking feel while you down shift and.
brokenjars
229
16
Kedah
Wah finally got a mivec hood. But this time will it disconnect and fly up again? Very dangerous if it happens again.
Wira update.
Are you going to do a hood pin latch? Cuz it sounds like your original latch doesn't hold tightly.
parakey
1,367
226
Yes,I bought a Mivec hood. I think is real one since is a metal one not fiber and is RM80.....juz need to cement it and spray or wrap it and is like a new thing..
RM80 is very cheap. Good find.
Looks ori but ori needs to modify the latch slightly. Front looks dented but I suppose you can have mudguard fella fix it for you. Unsure if extra putty may cause paint delamination later.
Putty for uneven surface, not for deep dents. Too thick later will crack and peel. Need mudguard guy to panel beat then putty back......lol
Reactions: sanekit
KHNG940413
668
56
johor bahru
Wira update
I had something wanna ask.
While I driving 70~90km/h and then i juz release the pedal let it slide and then I change my gear into neutral sometime the engine will mati togather.
Is that any issue for that? Or is it my driving style got problem?Hahahahahahaha
parakey
1,367
226
Maybe by killing off the engine, it's trying to save you more fuel.
Try checking your ilde control valve
Last time I can get RM 10 - 100 kms, but now RM 30 only 200 kms, RM 50 only 400 kms (last time RM 50 , 500+ kms.
What is the problem? my master pump just replace the seals yesterday, need to drive for 2-3 days again to see whether got leaking or not. Just want to list down the problem. Heard from the mech, the fluid all leaking inside the dunno what 'surbo'? :unsure:
And, early morning I start the engine got like black stain coming out from the exhaust. Engine oil? :blink: , i'm...
