Civic radiator
iameternal
67
6
40
Seen a few EG/EH some with "long" radiator and some with "short" radiator
Can i know why is it so? which is stock and which is modify or swap from other car?
which is better ?
thanks again sifu
Ranjanmax
121
Including myself in this post as I was about to ask for overheating solutions for my eg.. oil temp and water temp shoots up if I drive slow or in traffic jam.. FYI I’m using the SARD radiator (short one)
If im not wrong, during the days the stock radiator would be the short ones, and the long ones was from an integra? That was what I’ve been told
which is better ?
thanks again sifu
iameternal
67
6
40
found this half cut, looks like the long one is from dc2, answer my own question... haha
Reactions: Izso and Ranjanmax
Hahaha cheers man.. now the only question left is mine.. overheating and cannot enjoy Penang touge ady :(
Need to check your radiator fan, whether running or running at correct speed, whether thermostat opening fully, radiator flow, water pump etc...
But you say drive slow and in jam, now touge also overheat?
jebatdex
430
18
Skudai, Johor
last time my satria same problem, high temp during jam/slow moving, thermostat jam already, didn't fully open.
Ranjanmax
121
Yep.. drive to hard means oil temp rise water temp go down..
Short / long - in Protons usually means short rad = manual car rad. The long one usually taken from auto.
jebatdex
430
18
Skudai, Johor
actually i have the thermostat completely removed without replacement now. after reading a few articles, i think I will buy a new thermostat and install it back soon. huhu
Reactions: parakey
lsm1991
1,469
185
the con of running without one is your car will take longer to warm up...
The Marketplace Top Posts
Boss..wanna know if aircon receiver spoilt/the switch which control the rpm ( usually on top of the receiver ) spolt means what happen ???I've been having this problem recently and it's soo sickening.The rpm will be soo inconsistant and it effect the temp too.I brought it to a/con shop n that fella change the switch ( 2nd hand ..new one is pretty costly ).The next day the same problem happened.I'm feeling sick as the car is sooo inferior to drive !!Whenehev I stop ( eg traffic light ) the...
