sanekit
rebuild=overhaul. mivec is a bit "manja". need to check all the clearance properly, oil pressure, solenoid, everything.thanks about the ecu information.
rebuild properly? open up everything in engine and fix back?
that be bad if mekanic dont know on the clearance properly, oil presure, solenoid in original mivec setting. if setting run already, idle cannot stable? will like damaged the engine?rebuild=overhaul. mivec is a bit "manja". need to check all the clearance properly, oil pressure, solenoid, everything.
take it to workshop that had done proper build before. u bought the engine already? where do u stay?that be bad if mekanic dont know on the clearance properly, oil presure, solenoid in original mivec setting. if setting run already, idle cannot stable? will like damaged the engine?
i dont know any workshop in perak. haha. can only suggest you some workshops in shah alam.thinking about it. i stay on malim nawar. i dont know on work shop that can do a mivec proper build
what I know is my friend use ACL new bearing nearly all burn off after back from dynouse ACL or King bearings? hehe
dang.. maybe the bearing clearance not checked properly or oil starvation?what I know is my friend use ACL new bearing nearly all burn off after back from dyno
Dont know why also
maybe since ask him he said the engine not yet smooth after refurbish the internal to new parts.dang.. maybe the bearing clearance not checked properly or oil starvation?
So he knew the engine wasnt in good condition and yet he went for dyno?maybe since ask him he said the engine not yet smooth after refurbish the internal to new parts.
piston ring also nearly boiled
really dont know d.. maybe he thought all new internal is ok to go for dyno? before send to dyno he already thinking is there any problem since engine just running 300km and he also scared that engine will blown is didn't got for dyno..So he knew the engine wasnt in good condition and yet he went for dyno?
he is a foreman actually, he said all internal are new that he also feel wired how come like that..I believe it is just a case of badly build engine, did his mech measure the bearing clearance with plastigauge? there are too many variables, could be rod cap bolt failure as most people reuse them instead of replacing them.
not to make your friend look bad, just stating the truth, many foreman can maintain and overhaul an engine, the sad fact is not even a handful can properly build an engine to spec. many dont measure and spec engines individually which i also understand that it take up too much time.he is a foreman actually, he said all internal are new that he also feel wired how come like that..
he ask his friend to drive for dyno and that fellow had elephant leg..
maybe his elephant leg fried off the bearing cant imagine from sunway to botanic klang less 15 minutes at afternoon, really dont know how fast he drive
Regardless of elephant leg or not, dyno is stressful for the engine. So that shouldn't matter. If he ask the friend for a favor, then he shouldn't blame him.he ask his friend to drive for dyno and that fellow had elephant leg..
well he did not blame anyone just sad in heart and pocket...Regardless of elephant leg or not, dyno is stressful for the engine. So that shouldn't matter. If he ask the friend for a favor, then he shouldn't blame him.
what happened? Everyone...Proton spend money to make
a) Waja cost = RM1.2 billion
b) Gen.2 cost = RM1.3 billion
c) Savvy cost = RM850 million
With that cost Proton should produce car like Camry, Vios, City but sadly to said ....................... then compare with Produa
a) Myvi cost = RM580 million
Based on that figure, cost lower but quality & performance 3x better than higher cost................... What happen?
