Considering to buy the Audi A5. What the maintenance would be like?
esthapo
Trail Bomber
796
186
Sister'sBedroom
I was told by the tire shop owner his A4 suspension cost bout RM5K per piece....A5 should be more if not less....
is it true it cost that much?
marsha1l_v6
666
130
543
make sense i suppose..most conti now have this adaptive/active damper control...similar to tein edfc but way way way more expensive..
passat cc 2013/2014 ish, 1 pair close to 10k..uncle experience..
Hey there folks,
I'm an enthusiasted Audi manufacturer especially when it comes to Audi A5. I'm currently a Mercedes owner and i find it quite convenient when it comes to maintanance, it shouldn't be a major problem as if it has to compared with other continental cars. But i heard that audi has a big isssue on gearbox and it gonna cost me way too much $$$ if I have it maintained on it. Would it be relevant if I'm considering taking one? What are you suggestion? And how much do I have to spend per year priorly on maintenance etc. ?
Regards,
Naim Fauzi
New or used? If used which model?
For the full set la. Not per piece. Bilstein full set standard setup is 5k-ish for Audi A4/6
RENESIS VIII
7,063
950
Ipoh
Felt like sports car kind of maintenance instead of entry level executive car.
s.marz
261
18
28
oil consumption usually is caused by piston ring failure no?
AFAIK, the oil consumption problem is due to the manufacturing problem with their piston/rings so technically it came defect from the factory. Cars affected are A4, A5 & Q5 those equipped with 2.0T engines up to 2011. At some point in 2011, they've finally fixed it and cars manufactured after 2012 generally shouldn't experience it anymore.
Then the newer cars should be okay?
hi..does anybody knows where i can get silicone vacuum hoses for a cheap price for a large quantity of it?
