new tyre in front or rear?
ixeo
4,788
3,080
KL, Malaysia
hahaha no lar...peek from afar using binoculars only:biggrin:
peeking at BLaCkHoWLiNG & Tom ah. walao, after so many years they are still going at it.. guess once you go sideways, you buang and cannot recover straight anymore.
cvkit17
2,884
1,354
How do u know that I'm not peeping u also? U know when u buang u also spinnnn
kurt_629
872
54
johor
If start with 4 new tyres, yes, the wear in front very much more. Rear for FWD hardly wears.
That is exactly what the manufacturers mentioned. If you tent to understeer, you will slow down, rather than go faster and oversteer in a FWD.....lol:driver:
thats why this thread or topic is very confusing..
I guess I will still stick to new tyres in front..
I don't drive fast in rain, only like 150km :rofl:
its the front tyre that need to be replaced every few years
That's what I don't like, I'd rather maintain more or less still similar balance even though overall grip already reduced. Hence I always rotate if possible. Plus poor me don't have budget to change tires too often leh even if only 2. If I also only keep changing 2, I never get the experience of having all 4 brand new fresh rubbers to enjoy and can never evaluate them properly. :driver:
150kph is pretty fast in the wet la especially if got some sweepers, don't be nuts coz it can endanger others also. You're not Ayrton Senna bro!
kurt_629
872
54
johor
:biggrin:
joking only..
to be frank, I really did that few years ago..
I really have much confident in my handling, tyres and braking..
now, changed man.. 150km is out..
I will keep to speed limit during rainy days.
life no take 2 :biggrin:
You are different, because you follow 4 tyre change and do rotate.
As per topic. what if you need to change only 2 tyres.....lol:rofl:
sweelt
Nov 6, 2016
2,306
248
If rain, dont speed. Simple.
Duno when going to run out of luck.
My big luck,, is manage to avoid that crazy girl drive against flow.
No lottery luck, else buy neighbor house. :biggrin:
If heavy rain, even new tyres also have it's limits...:driver:
Tom
TIMETOATTACK
Jul 6, 2000
5,562
3,229
that's not a bad way to describe the car bug
ixeo
4,788
3,080
KL, Malaysia
I sailing boat ma, don't spin 1.
Basically you can stick it anywhere you want if you know what you are doing. Otherwise, always in the rear.
Sometimes I'm quite impressed with myself, making something so wrong sound macam yes.
Tom
TIMETOATTACK
Jul 6, 2000
5,562
3,229
I've been reading this and I'd like to chip in,
The science as to why new tyres should be in front (edited: I meant rear) is clear, but this will only work if your existing tyres are in good condition. It's counter productive if you've only got 50% or below left and you put that pair in front to be honest
The science as to why new tyres should be in front is clear, but this will only work if your existing tyres are in good condition. It's counter productive if you've only got 50% or below left and you put that pair in front to be honest
Agree on this, whether in front or in the rear depends on the thread balance of the old tyres too.....:driver:
well.. usually rear tyre is OLD but still got plenty of thread left....
so thats where i begin to put new tyre at rear tyre...and use older in front....
since FWD is faster wear infront... hence...old front will fully utilized...then when it time finished all the front thread...
buy new tyre and put at the rear again....
older rear which was previously was new then relocated to the front...
and the cycle continues.... :driver:
The Marketplace Top Posts
Hi sifus out there,
Recently I just got HWL hi-low soft-hard for my car (about 8 hours ago to be exact :) ), but the problem that keep bothering me all night long is about height adjustment for this thing. Since I wanted to set the car little high, the taukeh used to compress the coil spring to archive that, and for what I understand, height adjustment for this type of absorber is only to adjusting the body shift housing (cylinder body housing) and not to compress the spring. It will...
