marsha1l_v6
Crazy neat man...Hahaha..I can give u wire..Seems like u need more wire hahahaHei Guys.. car is shaping up..
IMHO every ATF can withstand heat. how high is the difference.Hi...
Does any 1 know whr2 find.dextron 6 atf gear oil....it seems can withstand heat ....its been release in U.S bak in 2006....good for those v6 n v8 in U.S....
Really bling bling......nice.......Hei Guys.. car is shaping up..
Agree, D6 is not suitable for Mitsubishi! U try then wish u good luckIMHO every ATF can withstand heat. how high is the difference.
also, is Dexron 6 suitable for Mitsu gbox?
Mitsubishi specified Diaqueen SP3 as the ATF to use.
install Pivot Speedmeter or Apexi RSMHi Sifu sifu... need an advise
Currently using stock ecu with safc.. with stock ecu cms the prob of speed limit.. any idea what to do..
speed limit? wow.. what speed you are on..Hi Sifu sifu... need an advise
2-step? tyre not spinning at 4k rpm?speed limit? wow.. what speed you are on..
another cheap way that I know, is to modify the chip in current ecu.
I saw a few that are doing this.
my current ecu also modified, no speed cut, launch at 4000rpm
what is 2 step?2-step? tyre not spinning at 4k rpm?
your ecu is rechip or?what is 2 step?
initial, tyre do spin..
like fast & furious
but after time, you know how to control, is still ok.. just controlling of clutch, slowly release
perdana chassis is quite heavy, not easy to spin..
I'm also using Potenza 002, 225/45/17
mine is a rechip, modify the main chip if I got it correct.your ecu is rechip or?
2-step is 2 different rev limiter, usuallly to build boost during launch.
i've seen perdana tyre spin through out 150-ish meter during drag day..even my manual last time spin out during launch.
where do you purchase your rechip? chop shop?mine is a rechip, modify the main chip if I got it correct.
Anyway I don't drag or race.. so to me, its overkill..
I only got it because my older ecu is damage, cannot control the boost.
When I boost, my wife will scold me..
anyway my driving habit also gentle..
I slowly release while in 1.5 - 2k rpm..
family car..
safety come first..
I got it from my mechanic, if I recall correctly, there's this guy who does such stuff in KL.where do you purchase your rechip? chop shop?
Looking for rechip to replace stock ecu..
My friend gave me a unit called speed limit defencer, but in the end did not install it as seldom hit until that speed.....Hi Sifu sifu... need an advise
