other than rims, bumper lining and ATF cooler, i dont really know. huhu..Hi all
What are the differences between of PV6 with enhance 2 & enhance 3 model?
__________________________________________other than rims, bumper lining and ATF cooler, i dont really know. huhu..
IINM Nothing much change between those model except:__________________________________________
Does any1 heard abt enhance 2 & 3 has issues compares to the earliers model ?...
It seems some of the earlier models selling more expensive than the later models.
-tune by lotus.
-alternator
-burnt gasket
power window unit
QUOTE]
Lotus came in and does the handling?
Alternator, yes. terrible.. I change 3 units.. now using 95a, still ok
Burnt gasket, my friend V6 also experience this.. full tank water, gone in few days..
Power window unit, terrible..
can go down but cannot go up..
basically its the gbox. but after installing ATF cooler. should be ok.__________________________________________
yea, the infamous tappet sound.hahahead gasket yes, after maybe 150K km, it starts to leak water or oil.
tappet sounding louder as the older the car gets.
power window no problem. only now (after 15 years), it starts giving me problem (on the driver side) coz always using it.
yup..remembered when naik USM perdana. quiet and smooth.-tune by lotus.
-alternator
-burnt gasket
power window unit
QUOTE]
perdana is good car..gbox spoil everything.Wah! 15years only power window spoilt, Wira one by year 8 change 3 times, and even rear manual wind mechanism change once....
Running hydraulic tappets like 4G63? I am now using diesel engine oil much quieter already......lolyea, the infamous tappet sound.haha
more or less the same..i just change EO from castrol magnetic semi to shell semi..poof, no more tappet.Running hydraulic tappets like 4G63? I am now using diesel engine oil much quieter already......lol
if i'm honest, its even worse. the hydraulic lifter sounded even louder. haha..Running hydraulic tappets like 4G63? I am now using diesel engine oil much quieter already......lol
Now using aftermarket ones, still with HDEO?if i'm honest, its even worse. the hydraulic lifter sounded even louder. haha..
maybe can find newer generation or aftermarket lifter with larger holes.
my 4G63T's lifter used to sound loud.
after using HDEO, sound lessen a bit.
but now after i changed the lifter to aftermarket ones with larger holes, bunyi tiada lagi. hahaha
Crazy neat man...Hahaha..I can give u wire..Seems like u need more wire hahahaHei Guys.. car is shaping up..
IMHO every ATF can withstand heat. how high is the difference.Hi...
Does any 1 know whr2 find.dextron 6 atf gear oil....it seems can withstand heat ....its been release in U.S bak in 2006....good for those v6 n v8 in U.S....
Really bling bling......nice.......Hei Guys.. car is shaping up..
Agree, D6 is not suitable for Mitsubishi! U try then wish u good luckIMHO every ATF can withstand heat. how high is the difference.
also, is Dexron 6 suitable for Mitsu gbox?
Mitsubishi specified Diaqueen SP3 as the ATF to use.
