Converted Car Chassis. Is it worth it?
g4i8y0t
1,216
330
683
Kedah
That means even for EK4 Civic SiR, the chassis is same with the rest of the EK lineup including our local CKD chassis?
As far as I know, yes. Only the front OEM strut bar is different. EK4's has different design (without hinges) compared to local EK model (with hinges).
RENESIS VIII
7,063
950
Ipoh
if dong full car spot weld will be much more stiffer than oem chassis, that one is race preparation for race dy
But do you think if lets say someone do a full spot weld on a Wira 1.5 or maybe Wira 1.8 C99 chassis, can they achieve the kind of stiffness in your CD9A? I don't think so after seeing your photos of areas with reinforced welds in Evo.
All EK came with strut bar originally?
If all EK chassis are same except for EK9, that probably explains why people are selling converted EK hatch at such high price. Since it doesn't matter whether they are local EK or JDM EK4 chassis, they are equally as good.
peterj
1,321
258
1,683
Kuching
Much more stiffer, mean for race use
lsm1991
1,469
185
ek9's, dc2's most type R's are the same as evos, they have some additional welds here and there.... errrr iirc rear towers and backside section are reinforced, duno whats diferent up front.
Even after spot welding, will the chassis be strong enough? I remember one of your old quotes about a Putra with chassis cracks.
Your quote back then.
Yes. But key word is "regularly went track". If you're planning to go track regularly - then I'd probably do more than spot welding. If it's just a daily drive, cracking a C99 chassis is going to be a tough affair.
RENESIS VIII
7,063
950
Ipoh
I see. So it is actually possible to further reinforce a weaker chassis with this race use method.
The Type R variants are definitely having reinforced chassis. But how about those one step below Type R models? The Civic SiR chassis? Or the Integra SiR?
So, that is the key point then. If one does not go to track often, a C99 chassis will be strong enough even for powerful engine swaps.
loose_end
3,649
197
Malaysia
Chasis
EK3 vs EK9 - Different
GTS/GTT vs GTR - Different
Satria vs Satria R3 - Different
Lancer vs Evo - Different
FD vs Type R - Different
How about Satria vs Satria GTi ? & WRX vs WRX STi
RENESIS VIII
7,063
950
Ipoh
Chasis
Well, those that you listed are clearly very different. The same goes for normal Satria C96,C97,C98 VS C99 Satria GTi. WRX vs WRX STI depends on which generation. The newer generations starting from GD chassis had a different chassis code for WRX and WRX STI. But the older GC8 are same I believe because WRX and WRX STI chassis are called GC8.
loose_end
3,649
197
Malaysia
Any idea how different is normal Satria vs Satria GTi. Thanks
lsm1991
1,469
185
Chasis
wana confirm.... you are talking about th neo r3 and the neo right??
iirc no difference in the chassis between these 2 models (i think)
also, later batch r3 neo's are basically normal neo's with some r3 gear while the earlier batch limited edition r3's are actually performance oriented from my understanding
peterj
1,321
258
1,683
Kuching
For me more stress on chassis driving on the street than track, due to special pathhole road in bolehland
RENESIS VIII
7,063
950
Ipoh
GTi's chassis is stiffer and more reinforced than normal Satria chassis.
The normal Neo R3 is just some Neo with added accessories. Unless you are talking about the limited edition Neo R3 Lotus Racing that comes in Lotus Racing Green.
As for the older GTi R3, I think that one comes with an even stronger C99 chassis.
Now that Satria and C99 topic has been brought up, anyone here actually knows is a C99 Satria GTi chassis as good as an original Mirage Cyborg-R CA4A chassis? The Mirage that came with 4G92 MIVEC.
Can potholes actually crack a chassis? Cracking wheels, yes, but chassis? :confused:
peterj
1,321
258
1,683
Kuching
years ago , not to bash or what, but there is a perodua viva owner put on photo to ask help for repair strut tower,cause hentam lubang besar,rim bengkok crack then strut tower spot weld also detached.
lsm1991
1,469
185
speaking about the neo's there are so many variants...
r3 clubsport - mild looking, had cage #win
r3 limited editions - i think these had a fancy plate with the number
r3 kited - nothing but kit, fancy seats, trim
r3 lotus ediion - green and this had the most fancy bits and power
if im not wrong, chassis used for all of em are the same, the clubsport had the extra cage and that was about it
i guess if the pothole is large enough and the force was great enough to bottom out your suspension and transmit enough force to mess everything up... yeah i guess?
CONGRATS TO 3 NEW ROTARY OWNER......we did all the Optimum no rinse wash & clay prior corrections
Thanks for allthe demo cars...1st was bro ario E60
I was supprise " when ario... called me yesterday ......even questioning what is his intention.......infact....as he mentioned his car was sent for a detailing job & he needed me to do a correction....???????
I apologies " for answering rudely..as disbelieve...
"u think I am god ka!!!!...must read in PCK slang!!!!(local comedian)
And he...
